Tire size differences?
Old Sep 13, 2004 | 01:15 PM
biggrizzly's Avatar
biggrizzly
2015 C5 of Year Finalist
Default Tire size differences?
What is the difference between 285/40/17 and 275/40/17 ?
I currently have the 275's on all four 9.5" A-mold rims. What difference would the 285's make?
Don Haller, Rockville MD
Old Sep 13, 2004 | 01:38 PM
vader86's Avatar
vader86
Its just a wider tire, more contact patch. The first number in any tire size is its width.
Old Sep 13, 2004 | 01:58 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
the first tire is 10mm wider.
Old Sep 13, 2004 | 06:14 PM
tempest's Avatar
tempest
the 285 would also have a bigger diameter by 8mm (10mm x 40% x 2).
Old Sep 13, 2004 | 07:18 PM
96CollectorLT4's Avatar
96CollectorLT4
275 is the width in mm/ 40 means 40% of the width is your sidewall height/ 17 is the size of rim in inches
The 285 will be 10 mm wider ( or one centimeter) and a tiny bit taller, absolutely safe to upgrade to with no worries of clearances. I have them on all four corners of my Vette, fits the 9.5 inch rim with no worries. And you can rotate tires front to back, to wear them out evenly.
To Tire size differences?
