Electronic climate control
Old Sep 14, 2004 | 08:37 AM
alfonso gomez's Avatar
alfonso gomez
Default Electronic climate control
My 87 Coupe is equipped with the electronic climate control. I usually use it full blast and the LED display reads "10" as the highest fan speed. The thing is that while driving the fan speed drops to about half for a while. Then it goes back to full speed. A while later it drops down. Then goes up again. It does that all the time even if I set it on "manual".
I took it to an AC shop but they had never done any work on these systems and they did not know if that was the wy it should work or not. They checked and the system has a full charge.
Is this the way it works or is something wrong?
Please help, it is hot and muggy down in PR.
Old Sep 14, 2004 | 12:49 PM
Jet-Jock's Avatar
Jet-Jock
Up to the point you said it did it under the manual setting, yes that is the way its suppose to work. It's trying to keep it at the desired temp setting by increasing air flow. Normally as you start moving the vehicle, I believe its 25 mph, it stays on one flow setting then kicks into auto mode as soon as it senses air flow, then adjust according to the internal temp on the vehicle vs the setting.
Old Sep 14, 2004 | 02:15 PM
SunCr's Avatar
SunCr
On Manual control, it should remain constant. You need to duplicate it in the garage and monitor voltage on the tan or brown wire at the module. This is the input from the dash and it should be constant 7 volts on manual 10. If it isn't the dash assembly is bad. If it stays the same, monitor voltage on the output or purple wire to the blower motor. It should be 12 volts and if it drops while the input remains at 7 volts, the module is usually bad. If it remains a constant 12 volts, the blower motor is probably shot, but check for high resistance on the purple wire.
Old Sep 14, 2004 | 02:23 PM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
on a similar note:
anyone know how to make the 'warmer' button work, turned the temp down to 60 when I first got it, because it was hot out, now.... it's cold at 6:30 AM heading towards the coast.
Old Sep 14, 2004 | 06:11 PM
SunCr's Avatar
SunCr
When the control buttons don't work, the control panel needs to be replaced. Some, however, report success by taking it apart and cleaning the contacts.
To Electronic climate control
