D44 C beam?
Old Sep 17, 2004 | 08:57 PM
Hippiehead025's Avatar
Hippiehead025
Default D44 C beam?
is it required for the D44 swap or no? also will an 85 C beam work on my 90 coupe if i swap it to a D44? thanks- Roger
also is this one bent? or is that the way its supose to look?
Old Sep 17, 2004 | 09:27 PM
byte_me's Avatar
byte_me
If you currently have a D36 rear...you will need the D44 C-Beam. The D44 is a little bit longer (in the nose) so the beam is shorter- and you will need the drive shaft as well for this very reason. Can't be certain about an 85 working on a 90...all manual tranny's after 84 had a D44 rear...the 84 was the only model (that I know of) that used a D36 with a manual tranny. and from your picture...that C-Beam looks ok...the one on my 84 (and the one I had from a 96) looked just like it...and I too thought it was bent! its contoured! Also I hear great things about those C-Beam plates sold by www.zfdoc.com not only will they make the install easier...but stiffen up the running gear to boot!
Cheers!
Old Sep 17, 2004 | 09:31 PM
silver & red CE's Avatar
silver & red CE
looks like mine, is that a 44 beam?
I've got mine off, putting a drive shaft loop on.
Eric
Old Sep 17, 2004 | 09:44 PM
Hippiehead025
yesi ts a D44 beam, and im doin the d44 conversion for an A4.....
Old Sep 17, 2004 | 09:51 PM
silver & red CE
what gear you running?
Old Sep 17, 2004 | 11:01 PM
Hippiehead025
imgonna put 375's in there.
To D44 C beam?
