Overheating
Old Sep 20, 2004 | 04:24 PM
TommyVelour's Avatar
TommyVelour
Default Overheating
Recently purchased low-mileage all-stock '95 LT1 6-speed; car overheats after 10-15 minutes in traffic. Replaced corroded radiator, new water pump, thermostat, and sensors. Fans are engaging per factory specs and engine still overheats? Any ideas......
Old Sep 20, 2004 | 04:47 PM
DukeDiablo's Avatar
DukeDiablo
Just what temps are you talking about when you say "overheating?"
Did you backflush the cooling system as well?
Did you change the thermostat before the flush? If so...you might want to check/change the thermostat again.
You can pull the stat again..and check it's functionality with a pan of water and a thermometer. Put it on the stove and check to see what temperature the stat opens on (if at all).
I only say this because I've changed out stats on vehicles...performed a flush that showed some pretty nasty results...and then got a stuck thermostat a week later. After changing the thermostat again...all was well. I think in my case I clogged the new thermostat with some rust/sludge right after putting it in.
Also make sure you bleed out the system. You may have a large pocket(s) of air in the cooling system.
Do you have an extreme amount of dirt/oil caked up on the motor?
I'm sure others will have questions/suggestions.
Old Sep 20, 2004 | 05:15 PM
eboler's Avatar
eboler
Pray you don't have cracked heads... does it smell like coolant after driven hot? Check for liquid in your cylinders.
Old Sep 20, 2004 | 06:04 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
Yeah, what DukeDiablo said. But, again, what are you considering overheating. Not unusual to get up to 220 in heavy traffic in summer. Turn AC on and see if temp goes down, too.
Old Sep 20, 2004 | 07:20 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Dumb question... What is a backflush??? Thinking about doing a coolant flush soon.
Old Sep 20, 2004 | 08:51 PM
DukeDiablo's Avatar
DukeDiablo
You are flushing the coolant through the cooling system from inside the closed system. I'm probably not explaining this very well.
You are actually flushing the cooling system from the "back", or behind the thermostat. Hmm, still not very coherent...sorry.
It involves hooking a garden hose in-line with the system..and using the water pressure to flush it.
In any case...
Prestone makes a cheap backflush kit that you can install on just about any car.
http://www.acehardware.com/product/i...254883.1254883
http://forums.govteen.com/showpost.p...5&postcount=12
To Overheating
