Steering Toe Adjust Question
Old Sep 20, 2004 | 08:37 PM
Big Willy's Avatar
Big Willy
Default Steering Toe Adjust Question
I need a slight toe adjust. My GM service manual says to loosen the Lock Nut on the Inner Tie Rod and turn the Tie Rod, not the Tie Rod End. If the GM manual says thats the procedure, who am I to question? I'm just not sure about the other end of the Rod that goes into the Boot. Didn't want to screw-up anything. Anybody done this before?
Old Sep 20, 2004 | 10:57 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
The only thing you may need to watch is that your boot isn't stuck to the tie rod. Watch that when you turn it and if it isn't stuck your home free.
Old Sep 21, 2004 | 01:25 AM
Frizlefrak's Avatar
Frizlefrak
Exactly as the manual says, it won't hurt a thing.
But if it were my car, $75 for a quality 4 wheel alignment would be the ticket. In my experience, the C4 is very sensitive to changes in toe, and even small changes that aren't in spec can detrimentally affect handling. Do you have an alignment jig set up in your garage?
Old Sep 21, 2004 | 08:27 AM
-=Iron Mike=-'s Avatar
-=Iron Mike=-
I've done it myself with no problems. Don't over turn the tie rod though, very little adjustment is needed to make a major change.
To Steering Toe Adjust Question
