dumb question
Old Sep 22, 2004 | 06:01 PM
PsychoNumber1's Avatar
PsychoNumber1
From: Behind The Redwood Curtain, The State of Jefferson
Default dumb question
A while black I blew a seam on my radiator. I replaced it myself and everythin is fine, but the service engine soon light is on. Do I need to take it somewhere to be cleared or what? I still don't have the repair or owner's manual, but will someday. Any help with this simple question would be great!
Old Sep 22, 2004 | 06:56 PM
NightFlight's Avatar
NightFlight
To clear the code, disconnect your battery (neg cable) for @ 10 secs and reconnect. If the problem has been fixed, the light should stay off.
Old Sep 22, 2004 | 07:45 PM
ductape's Avatar
ductape
Cruise-In V Veteran
And just for the record, there ain't much you should do WITHOUT disconnecting the battery. It'll end up big $$$
Old Sep 22, 2004 | 09:32 PM
CoolVette86's Avatar
CoolVette86
From: Partying with the Cowboys cheerleaders in Mt. Olive, New Jersey
By the way, did you happened to check the code to see what it is? If you can jump a wire at the ALDS, read the codes and post it. Those of us with shop manuals will tell you what they are. It could be something unrelated to what you've repaired.
Old Sep 22, 2004 | 11:22 PM
PsychoNumber1
I'll disconnect and see if t stays off. I'll keep you posted.
To dumb question
