shocks
Old Sep 26, 2004 | 09:14 PM
redvette6spd's Avatar
redvette6spd
Default shocks
how maney miles on avarege does a 96 have on it be for it needs shocks
Old Sep 26, 2004 | 09:52 PM
silver & red CE's Avatar
silver & red CE
Shocks on a 96 are easy to test. Pull it off and see if you can move the piston by hand. If you can, time for new shocks.
Eric
Old Sep 26, 2004 | 10:32 PM
vader86's Avatar
vader86
Usually about 75K, given normal driving.
AutoX'ers would probably need it long before that.
Old Sep 27, 2004 | 12:36 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
As a point of reference, I bought my car with 81,000 miles on it and it had one front and one rear shock that were completely shot. Obviously, there are many variables that could enter into it, but in any case they should be replaced before that many miles.
Old Sep 27, 2004 | 01:18 AM
yellowlust's Avatar
yellowlust
the answer is YES.
Old Sep 27, 2004 | 01:50 AM
JrRifleCoach's Avatar
JrRifleCoach
From: Freedom is never more than one generation away from extinction.
St. Jude '03 thru '24
Originally Posted by yellowlust
the answer is YES.
My rule of thumb for "stock" type shocks has always been 30-50K miles. I'm sure you can go further, but why?
-JRC-
Old Sep 27, 2004 | 08:35 AM
runner140*'s Avatar
runner140*
Default When do we need shocks
I have a 1996 and it needed new ones at around 75000. They are a cheap and somewhat east to install.
Old Sep 27, 2004 | 09:40 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
If you feel the need to ask, then it's time to replace.
It depends on what you require from your shocks. You don't give us much information for your particular situation. I've heard of some members who still have the original Bilsteins on at 100K miles plus! Bisteins should last for at least 80K miles, but those last several thousand they may be marginal.
In short, too many variables to call it. Change 'em. Shocks are too important and too inexpensive to take the chance.
Larry
Old Sep 27, 2004 | 09:48 AM
EPiC Vette's Avatar
EPiC Vette
Found out mine needed shocks when I started hearing this "tinking" sound from the frt pass side going over bumps. Even slow speed bumps. Did a visual, saw the "innie" part of shock was kinda bent and scraping against the "outie" part.
When I pulled the shock, it came apart in two pieces ! The drivers side would only "compress"... no "rebound"
I was impressed the 'vette drove as well it did with those POS parts.... btw, they weren't stock (white KYB-like product, but made in the US of A! About $14 @ or so from Kragens, I think..), and I replaced at about 100K miles.
Old Sep 27, 2004 | 10:11 AM
yellowlust's Avatar
yellowlust
Another good sign is oil on the outside of the shock. Apparently some is ok, I'd say very, very little, but if the shock is pretty covered it's safe to say it's time. The good news is that you'll only spend some $120-$300 for shocks if you do it yourself and it's easy.
Old Sep 27, 2004 | 10:22 AM
DINO's Avatar
DINO
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
I went to Cruise-In V with Vetteweiser
Had to have my 2 front bilsteins changed at about 38,000 miles ....
To shocks
