SYS message and AC not Working
Old Sep 28, 2004 | 10:06 AM
oaseagle's Avatar
oaseagle
5th Gear
Default SYS message and AC not Working
Dear Vette Friend
Im new to this world of corvette because I just got my first vette 92
the problem that I have is that I have a message flashing SYS and the AC panel is off and none of the key like "TRIP" FUEL or Gauges work the display is stock in the last diplay wich was temp and I cant turn the AC on or OFF or Change the display
Help Please
New Vette Owner
Eagle
Old Sep 28, 2004 | 12:19 PM
Jet-Jock's Avatar
Jet-Jock
Have you check the fuses? Almost sounds like a blown fuse because so many things are inop. In your owner's manual there is a list of them and where they are located. If you don't have an owners manual, I believe National Corvette Museum provides them free of charge in PDF format.
Old Sep 28, 2004 | 04:52 PM
oaseagle's Avatar
oaseagle
5th Gear
thanks for your advise I will check that hopefully will be only the fuse LOL
Old Sep 28, 2004 | 08:20 PM
oaseagle's Avatar
oaseagle
5th Gear
well I change the Fuse and all the light are on again but when I push "auto" blow the fuse again I try even with a fuse of 20 and blow too
Any suggestions?
Old Sep 28, 2004 | 08:38 PM
Jet-Jock's Avatar
Jet-Jock
Replace the fuse and see if you can get it into diagnostics mode. push and hold the up/down arrow buttons at the same time for 5 seconds. The LCD will display 00 Push auto fan and it will display AC codes.
Does it only do this when you press Auto AC (not fan switch), what about defrost or vent?
Also which specific fuse is it blowing?
Old Oct 2, 2004 | 05:33 PM
oaseagle's Avatar
oaseagle
5th Gear
Little update I did get to put it to Diags mode but I also discovery they everything work if the engine is not running when I turn on the car and try the AC boom the fuse s gone !!!
thanks for all your help
Old Oct 3, 2004 | 09:26 PM
oaseagle's Avatar
oaseagle
5th Gear
Well I finally found the problem it was a cable in the compressor that was bad so I fix the cable and its working fine now
thanks for your help I coulnt fix with out your advise
Old Oct 3, 2004 | 10:41 PM
Jet-Jock's Avatar
Jet-Jock
Glad to hear a successful outcome.
To SYS message and AC not Working
