help with SRC code 13 on 90 vette
Old Oct 23, 2004 | 06:02 PM
Dads90's Avatar
Dads90
Default help with SRC code 13 on 90 vette
anyone know what code 13 is refering to on my Service ride control or is their a list of codes I can reference. Thanks
Old Oct 23, 2004 | 10:55 PM
SunCr's Avatar
SunCr
As best as I know, it means the actuator on one of the rear shocks failed a self test or didn't move to a pre-determined position within a set time frame as monitored by the module. Best to get a Shop Manual to troubleshoot the module and actuators which I believe can be accomplished with a DVM. On the other hand, if this is a History Code, clear it (disconnect the battery) and if it doesn't return, it was simply a momentary burp.
Old Oct 23, 2004 | 11:14 PM
Dads90's Avatar
Dads90
Do you know if the whole system shuts down if one actuator is not operating. I take off the front act. watch its movement and it only rolls when i first turn the ignition on. It does not respond to the selective switch at all. It seems it should react in some way. What do you think.
To help with SRC code 13 on 90 vette
