PKE range
Old Oct 25, 2004 | 08:00 AM
bsimard's Avatar
bsimard
Default PKE range
My PKE works with a diminished range. I walk up to the car and hold the FOB about a foot forward of the door handle and then the system will work. As soon as I get into the car, with the keys in my hand, the car will lock. I replaced the battery, with no change in range. I checked the voltage of the 3 volt battery, (it read 3.24 volts) so do not suspect that as the issue. I've cleaned the contacts within the FOB with no improvement. Range is similar at both doors.
Any ideas?
Old Oct 25, 2004 | 08:11 AM
Da Mail Man's Avatar
Da Mail Man
Any ideas?
GREETINGS,
WHILE I HAVE NO "DEVICE" SUCH AS THAT ON MY CAR, I HAVE FIXED ONE FOR A MERCEDES THAT WAS HAVING THE SAME PROBLEM. WHAT I DID WAS OPEN THE UNIT AND FOUND AN ADJUSTMENT FOR THE FREQUENCY THAT THE UNIT WORKED ON. APPARENTLY, FORM GETTING BANGED AROUND A BIT, THE FREQ. SHIFTED. SO, WHAT I DID IS MARK THE CURRENT LOCATION/SETTING OF THE ADJUSTMENT (LOOKS LIKE A BRASS FLAT SCREW OF SORTS) WITH "WHITE-OUT" AND LET DRY. THEN, I INSERTED A SCREWDRIVER OF SORTS (NON-METALLIC, BUT NOT TOTALLY NECESSARY) INTO THE ADJUSTMENT (AS ABOVE) AND "BUMPED" IT OVER A BIT TO EACH SIDE 'TILL THE FREQ. WAS MATCHED AND THE THING WORKED! THEN, I TOOK HOT CANDLE WAX AND DRIPPED A DROP ON THE EDGE OF THE ADJUSTMENT SO THAT THE THING WOULD NOT MOVE. IT WORKS LIKE A CHAMP!!...EVEN BETTER THEN WHEN MY FRIEND BOUGHT THE CAR. HOPE THIS HELPS.........LET ME KNOW!
Old Oct 25, 2004 | 08:27 AM
bsimard's Avatar
bsimard
Originally Posted by Da Mail Man
GREETINGS,
Thanks - I would never have thought of that. I'll give it a try.
Any other ideas?
Old Oct 25, 2004 | 08:28 AM
Da Mail Man
Any other ideas?
.........A-OK......ANYTIME
Old Oct 26, 2004 | 07:33 AM
bsimard's Avatar
bsimard
GREETINGS,
WHAT I DID WAS OPEN THE UNIT AND FOUND AN ADJUSTMENT FOR THE FREQUENCY THAT THE UNIT WORKED ON. MARK THE CURRENT LOCATION/SETTING OF THE ADJUSTMENT (LOOKS LIKE A BRASS FLAT SCREW OF SORTS) WITH "WHITE-OUT" AND LET DRY. THEN, I INSERTED A SCREWDRIVER OF SORTS (NON-METALLIC, BUT NOT TOTALLY NECESSARY) INTO THE ADJUSTMENT (AS ABOVE) AND "BUMPED" IT OVER A BIT TO EACH SIDE 'TILL THE FREQ. WAS MATCHED AND THE THING WORKED! THEN, I TOOK HOT CANDLE WAX AND DRIPPED A DROP ON THE EDGE OF THE ADJUSTMENT SO THAT THE THING WOULD NOT MOVE. IT WORKS LIKE A CHAMP!!............LET ME KNOW!
I must believe that by "...open the unit..." you mean the sending unit in the car as there does not seem to be any adjustment on the FOB. Is this correct? It will take me another few days when I have some time to tackle that, as I understand that unit is located behind the information center in the 95's, but I'll keep you posted.
Old Oct 26, 2004 | 07:36 AM
Da Mail Man
NO.....YOU HAVE TO OPEN THE "HAND HELD UNIT". SOME OF THESE ARE TRICKY TO OPEN BUT, THEY DO OPEN. THERE IS NO ADJUSTMENT OR SHOULD I SAY, YOU SHOULD NOT BE FOOLING AROUND WITH THE CAR MOUNTED UNIT.........
Old Oct 26, 2004 | 08:05 AM
bsimard's Avatar
bsimard
Darn, the "hand held unit" or FOB does not seem to have the adjustment you found on the Mercedes. It is simply a printed board and contact posts so the manual button will work.
Old Oct 26, 2004 | 08:08 AM
Da Mail Man
WHEN YOU OPEN IT UP, EXACTLY, AND TO THE BEST OF YOUR DESCRIPTION, WHAT DO YOU SEE?.....IN SOME CASES THERE IS A COIL OF WIRE OF SORTS THAT HAS A "FERRIT SLUG" ON THE INSIDE. THE POSITION OF THIS SLUG VARIES THE INDUCTANCE OF THE COIL AND WILL CHANGE THE FREQ. .
Old Oct 26, 2004 | 08:12 AM
bsimard's Avatar
bsimard
I'll be damned. I'll take a picture of it tonight and post it so you can see what I'm looking at. Thanks for your help.
Old Oct 26, 2004 | 08:14 AM
Da Mail Man
CHECK YOUR "PRIVATE MESSAGES"
Old Oct 26, 2004 | 03:21 PM
PreferEuroRacing's Avatar
PreferEuroRacing
Mine was doing the same thing and the battery read fine on a meter. Remember, however, that the meter reading is with no load. You can have a battery read full voltage but put a load on it and down it goes.
I was getting about 1-2 ft. range, too. I changed the battery and it's fine now, about 10-15 ft.
Old Oct 26, 2004 | 03:49 PM
Da Mail Man
I Agree. All That I Have Said Was/is The Reasonable Assumption Of A Good/new Battery Which I Am Sure Was Tried.
Old Oct 27, 2004 | 01:12 AM
yellowlust's Avatar
yellowlust
Sweet Lord, someone finally found the Cap Lock...
Old Oct 27, 2004 | 07:25 AM
Da Mail Man
WHAT'S IT TO YOU?...I FOUND IT AND NEVER LOST IT AND THERE IT SHALL STAY.....
To PKE range
