Will the LS1 engine fit in the C4?
Old 11-01-2004, 02:06 PM
IMXCITD
Support Corvetteforum!
IMXCITD's Avatar
Default Will the LS1 engine fit in the C4?
Will the LS1 fit in the C4? Anyone completed this swap?
thanks
Bill
Old 11-01-2004, 02:17 PM
KyRP2NITe Corvette
KyRP2NITe Corvette's Avatar
I've seen BBC in C4's so if a BBC will fit in a C4 the LS1 should fit just fine.... now how much of the rest of the drive line will need modification I don't know... If it bolts straight up to the tranny then it should almost be a weekend project..that of course is excluding the differences in the wiring harness.....blah blah blah..
Old 11-02-2004, 11:41 AM
redvtt
redvtt's Avatar
Location: All great change begins at the dinner table Ronald Reagan
GM sells a "universal" wire harness for the LS1. That way you can install this engine into anything it'll fit into. I started to look into this awhile ago - an LS6 crate motor $7700.00. If this was done on a c4, you could lose about 100 lbs (or so) in the front end.
I decided if I was to go that far, I'd put the money towards a c5/ZO6. However, if I wasn't in Cali, I'd be looking into the 576ci BBC, that would be the setup!!
Old 11-02-2004, 03:22 PM
bogus
bogus's Avatar
this topic has been nothing short of beaten to death.
yes, it will fit.
no the ZF6 won't mate up.
yes, the T56 will, but it requires custom brackets.
To Will the LS1 engine fit in the C4?
Quick Reply: Will the LS1 engine fit in the C4?
