TPI intake differences
Old Nov 19, 2004 | 10:43 AM
86_RedRider's Avatar
86_RedRider
Cruise-In V Veteran
St. Jude Contributor '03 & '05
Default TPI intake differences
I'm looking at picking up a spare tpi base manifold to experiment with. I have an 86 with iron heads. What years are same and what are the differences in the other years? I think there was a change in the intake bolts for the aluminum heads. What f-bodies would work also (if any)?
TIA
Old Nov 19, 2004 | 12:54 PM
redvtt's Avatar
redvtt
From: All great change begins at the dinner table Ronald Reagan
The early TPI intake manifold, they used a 305ci manifold for development and production. I think it was up to 87. Lingenfelter has a book on SBC, in it has a chapter on this. Lingenfelter said that any mods you do to a 350ci engine with the use of this early manifold is like using a 2 barrel carb instead of a 4 barrel. I'm not sure if it changed in later years.
Old Nov 19, 2004 | 01:47 PM
vader86's Avatar
vader86
TPI units are the basically the same in size and shape, but I believe the base is just a little different throughout the years due to EGR differences and some bolts and stuff.
I would think 86-91 interchanges but there may be one or two small things that changed.
Old Nov 19, 2004 | 02:40 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Intake bases after '86 have revised center bolt angles; Vette bases have the provision for external EGR at the rear of the base whereas F-body bases have internal EGR gas flow.
You may be able to use a base from an '87-'88 on your '86 by simply modifing those center bolt angles; the cold start injector was not used on '89 and later TPI so the base may differ here too (runners do).
To TPI intake differences
