Dimmer light switch problems
Old Nov 19, 2004 | 11:47 PM
qwiketz's Avatar
qwiketz
Default Dimmer light switch problems
Hey guys. Sometimes when I hit bumps, then the interior lights will flash on for a second. The dimmer thing doesn't feel like it's loose at all. The part that you adjust with your hand doesn't appear to be moving.
Once in inclement weather, it caused the stock alarm system to go off.
Is this a common problem? How can I rememdy it?
Old Nov 20, 2004 | 12:44 AM
bogus's Avatar
bogus
you have a bad door switch.
Old Nov 25, 2004 | 03:39 AM
qwiketz's Avatar
qwiketz
cool, thanks. I had my door handles changed about a month ago and maybe that caused it to go bad or something... It wasn't doing it prior to that.
Old Nov 25, 2004 | 10:01 AM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Check your hatch switch also
To Dimmer light switch problems
