header question
Old Nov 27, 2004 | 06:40 AM
drvn2fast's Avatar
drvn2fast
Default header question
what benifits would i get from putting headers on my 87 if any with no other mods to the engine just yet. should this be my first engine mod?? thanks guys
Old Nov 27, 2004 | 12:27 PM
redwing76's Avatar
redwing76
It depends on the header. Short tube 5-10 horsepower.
Long tube twice that. Long tubes are illegal.
If you buy any header get it in stainless. CRS headers are bunk.
Old Nov 27, 2004 | 01:28 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
You are on the right track to do exhaust but you will get the most gains from doing coated LT headers, a hi-flow cat, and a good cat-back at once. for the combination you may get 35chp gain. If you can't do all at once, start at the rear and do the cat-back; then do the cat, followed by LT headers. Whe I did cat-back, cat & front Y I got about 17chp gain; then doing LT headers would add another 17chp or so.
You should also do the cut air filter lid with K&N filter or a ram-air setup, low temp T-stat with fan switch (do you have a booster fan in front of the radiator?) and an AFPR to boost fuel flow at WOT as needed to match air flow increases from bolt on mods.
Before you get too far into engine mods consider your goal and select the parts to work together for best results.
Old Nov 27, 2004 | 02:14 PM
mikey whipreck's Avatar
mikey whipreck
Only in CA...
hell, I passed a PA emmissions test with a hollow catalytic converter.
Old Nov 28, 2004 | 02:08 PM
drvn2fast's Avatar
drvn2fast
i was looking at long tubes, but i think i will look for shorts
Old Nov 28, 2004 | 02:41 PM
TA's Avatar
TA
Originally Posted by mikey whipreck
Only in CA...
How long ago was this.............the new PA emissions are pretty stringent.
Old Nov 28, 2004 | 03:57 PM
McShagger's Avatar
McShagger
Only in CA...
Really? I thought I saw a dude with LT headers and cats on... would that make it legal?
Old Nov 28, 2004 | 06:10 PM
torchred89's Avatar
torchred89
I have TPIS headers and straight thu cat and power effects exhaust and mine passes VA state emmissions
To header question
