Reverse shift lever
Old Dec 8, 2004 | 01:49 PM
pope8ss's Avatar
pope8ss
Default Reverse shift lever
.....rattles like crazy. Anybody have this problem, and know how to fix it? It's really annoying
Old Dec 8, 2004 | 02:35 PM
1quik91's Avatar
1quik91
What do you mean reverse shift lever? You mean when you are in reverse it rattles? auto or manual?
Old Dec 8, 2004 | 04:17 PM
Shore's Avatar
Shore
Ahhhh....I think I know what he's talking about...the little reverse-lockout ring that pull up....Mine rattles ALL the time.It's not big time loose or anything but that little bit of play and it vibrates...it makes ahelluva racket for what it is.
I have not come across any solutions...was thinking some grease on the shaft would shut it up.....
Old Dec 8, 2004 | 05:25 PM
pope8ss's Avatar
pope8ss
Exactly! I end up having to keep my hand on it when I drive.
Old Dec 8, 2004 | 05:26 PM
pope8ss's Avatar
pope8ss
I'm afraid to put grease on it cause your hand is always on it.
Old Dec 8, 2004 | 06:20 PM
Shore's Avatar
Shore
I was thinkn just on the shaft it rides on.You never touch that part...just haven't gotten around to it....lol
I too keep a finger on the handle to hush it up...amazing the rattle that little bugger makes...lol
Old Dec 8, 2004 | 06:32 PM
pope8ss's Avatar
pope8ss
Let me know if it works
Old Dec 8, 2004 | 09:29 PM
94redrag's Avatar
94redrag
Mine used to rattle. Finally I loosened up the set screw that holds it it place and raised it up just ever so slightly and while holding it in the ever so slightly raised position, I retighten the set screw. Now I have no more rattle! This worked for me, no guarantee it'll work for you. But its worth a try. Good Luck
Later, Zane
Old Dec 8, 2004 | 09:36 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Simple solution, switch to the Hurst Billet Plus shifter.
To Reverse shift lever
