how does a vette act when its missing
Old Dec 21, 2004 | 06:05 PM
rustangkiller's Avatar
rustangkiller
Default how does a vette act when its missing
took my vette to a tranny shop because when i get on it the rpms go up but the tires dont spin and i dont accelerate. it only happens when the pedal is down atleast half way. it shifts great other wise. they told me that when its doing that its missing and can give the wrog signals to the tranny. when it sitting at idle you can feel a realy light rumble but not enought to move the tach away from 500 rpm. i would asume this is normal because of the size of the motor. so i have no clue whats going on.
Old Dec 21, 2004 | 06:06 PM
rustangkiller
also if it is missing what could that be. an opti. i had the plugs done by the stealership about 6 months ago.
Old Dec 21, 2004 | 07:24 PM
bogus's Avatar
bogus
Gee. I never missplaced my Vette... so I don't know how it sounds when it's missing. I hope I never find out.
A part throttle miss... hm...
1994 is electronic, so there is a chance an engine miss could be messing with the shift program.
Opti is a good thought. Also, coil, coil wire and fuel filter.
what about miles??? how many?
Old Dec 21, 2004 | 07:42 PM
jsup's Avatar
jsup
From: Bergen County, NJ Democrats, doing for the country what they did for Michigan
Let the car run in the dark, see if you see fireworks under the hood, sparks jumping. That may tell you where and if you're loosing spark.
Old Dec 21, 2004 | 09:31 PM
rustangkiller
its got 77k. fuel filter huh. if the rpms go up but the car doesnt go foward faster, could that still be a miss. like maybe 7 out of the 8 cylinders are going or somthing?
Old Dec 21, 2004 | 09:46 PM
VenkmanP's Avatar
VenkmanP
Feels like any other car that is missing. Sorry can't describe it but it's not different than another type of car.
I had a plug wire that got slightly burned and caused a miss under acceleration. Sitting still it was fine, but when I started moving I guess the burned part moved closer to something metal.
Old Dec 21, 2004 | 09:49 PM
VenkmanP's Avatar
VenkmanP
Also I'd get another opinion on the tranny before digging into the other stuff. I don't think a miss would cause your trans symptoms, but I'm no tranny expert.
Old Dec 21, 2004 | 09:53 PM
rustangkiller
thanks. i think im going to take it to the stealer ship. those guys had a dual bay garage and probly dont know what there talking about.
aj1988's Avatar
aj1988
If you can't find an electrical reason for the miss, have someone checkout your cat. I had my main cat clog and while the car would start and drive, somewhere around 3000 rpm it felt like the tranny was going out, no power at all.
I don't know if you have pre-cats or not, but if you do have them check the main cat first then the pre-cats. They replaced my pre-cats and then it turned out to be the main cat
To how does a vette act when its missing
