high rpm engine problem
Old Dec 25, 2004 | 08:40 PM
prodadiv's Avatar
prodadiv
Default high rpm engine problem
I just got a 1990 Vette and withy my luck the engine seems to
quit or bog down at high rpm's (3800). It idles fine but when
accelorating hard it seems to have problems. It now has flowmaster
mufflers and a K & N cone air filter. There are no great places for
service in my area and the dealer is too expensive. I'd appreciate any
suggestions. Oh and my electronic heater doesn't seem to blow hot air.
Wish my wife was the same!
thxs in advance
Pete
Old Dec 25, 2004 | 09:40 PM
19corvette91's Avatar
19corvette91
check your fuel pressure.......
Old Dec 26, 2004 | 01:13 AM
comp's Avatar
comp
still have the cats. on ???? mileage???
Old Dec 26, 2004 | 10:41 PM
lensvet's Avatar
lensvet
St. Jude Donor '05-'07-'08
I agree Check the cats.
Old Dec 27, 2004 | 12:56 AM
bogus's Avatar
bogus
start with the precats. Work your way back.
Do you have the helms manual? The best best is to get one. www.helminc.com
Where do you live? When was the last tune up?
Check Engine Light on?
Old Dec 27, 2004 | 09:38 AM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
There are several things it could be... and the info given was rather vague.
Old Dec 27, 2004 | 12:08 PM
redwing76's Avatar
redwing76
thxs in advance
Pete
Change the fuel filter.
Old Dec 27, 2004 | 12:12 PM
Sandy S's Avatar
Sandy S
Fuel filter is a cheap place to start.
lso check the air filter. Are there any codes showing? How many miles on it?
Old Dec 27, 2004 | 10:03 PM
prodadiv's Avatar
prodadiv
It was recently tuned up and exhales through flowmaster.
I disconnected the alternator and the bog stopped.
When I reconnected it the mis started again. Can you
help me figure this out?
Old Dec 28, 2004 | 01:24 PM
redwing76's Avatar
redwing76
I had a Ford Festiva that did the samething. The alt was bad and at night it would bog down the tiny 4 cyl. New alt no more problem.
I don't think its the same problem on your car though.
How did you disconnect the alt, by the the belt or a lead?
Do a voltage chk on the bat and the alt.
Old Dec 28, 2004 | 04:43 PM
prodadiv's Avatar
prodadiv
I disconnected the leads to the alternator. An auto parts place checked the alternator and said it was running fine, although it was checked only at idle, I'm not sure what it would be putting out at 3800 rpm. It does not miss while disconnected.
Old Dec 28, 2004 | 06:27 PM
redwing76's Avatar
redwing76
On my work car another Ford the alt would drop the brushes at anything over 2500 rpm the battery light would light up till you backed off the gas. It would check out fine till you got on it. It never missed though.
Months later it gave up the ghost.
It doesn't miss while disconnected? Man thats a wierd one.
If its the alt then your battery should be in a discharged state?
It doesn't make any sence unless your not getting enough voltage to your ignition system. But then it should run even worse with the alt dis-connected? Unless the alt is pulling a huge drain on your electrical system? It sounds like it could be your alt.
Anyway good luck this is a tricky one.
To high rpm engine problem
