pke question
Old Jan 3, 2005 | 06:24 PM
bensfirst94's Avatar
bensfirst94
7th Gear
Default pke question
hi all and happy new year i am a new owner of a 94 yette and love it i find your forum very helpful and you are all very knowledgable. my question is i just bought a new pke controller should the door and hatch button work also the car doors work automatically when i approach and leave the car but the buttons for the door dont seem to respond should they??? thanks for all the help
Old Jan 3, 2005 | 06:30 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
Yep, the doors should lock, horn beep when you walk away. BTW, don't buy the directions to program your FOB from Ebay, I think they are here in the tech area, take a look. You may just have to program it.
Old Jan 3, 2005 | 06:49 PM
FD2BLK's Avatar
FD2BLK
Here is a tech tip I posted a while back
https://www.corvetteforum.com/techti...=267&TopicID=2
I didn't post it but you can also arm and dis-arm the system by holding the door lock button untill the door locks cycle on the drivers side (about4-10 seconds). when the system is armed it will lock and unlock automaticly.
Old Jan 3, 2005 | 06:58 PM
bensfirst94
7th Gear
thanks for the tips i have it programmed and it works good i just didnt know if the door button and hatch button on the fob should work also
Old Jan 3, 2005 | 07:27 PM
FD2BLK's Avatar
FD2BLK
The door button, when armed should open the pasangers side, and the hatch button should also work and pop the hatch if you are with in range. If the buttons are not working try, disarming the system then re-arming then if it they still don't work try reprograming and see if it helps. If non of the above fixes the problem it may be a bad remote
Old Jan 3, 2005 | 07:41 PM
VenkmanP's Avatar
VenkmanP
Alternately you could read the programming intructions in the owners manual.
Old Jan 3, 2005 | 09:44 PM
bensfirst94
7th Gear
it all works fine thanks for all the help
To pke question
