85' Vette Pinging Problem
Old Jan 10, 2005 | 02:52 AM
nitronick's Avatar
nitronick
Active Streak: 90 Days
Sea Foam
Old Jan 10, 2005 | 04:34 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Crank sensor?
What did you do before it started,did the distributor get wet?
Old Jan 10, 2005 | 10:12 AM
kcpaz's Avatar
kcpaz
could the crank sensor be bad, or do you mean that it could have been unplugged??? No the distributer didn't get wet. the car just passed an emissions tests with flying colors.
Old Jan 10, 2005 | 10:30 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
What octane rating are you putting in it? If not 93 then try some and see what that does.
Old Jan 10, 2005 | 11:45 AM
redwing76's Avatar
redwing76
Originally Posted by REDC4CORVETTE
Crank sensor?
Crank sensor on a L-98?
Old Jan 10, 2005 | 01:07 PM
Frizlefrak's Avatar
Frizlefrak
I dunno about "crank sensor", but the knock sensor may be disconnected or damaged. It's job is to retard timing if it detects detonation. Passenger side of the engine block, down by the oil pan. Check and see if the wire has come loose, or if the sensor itself is broken. BTW, should you need to change it, it spews coolant when you remove it, so wear eye protection and be ready to stick the new one in the second the old one comes out.
The manual calls for 6 degrees of timing, but you should be able to get away with more and pick up a little low end power. I'm running 10 degrees of base timing on my 84 on regular fuel with no detonation.
BTW, I trust you have smarts enough to back off the throttle if it sounds like the motor is crushing marbles. Bad detonation is an easy way to burn a hole in a piston. Find this problem and fix it ASAP.
Old Jan 10, 2005 | 01:47 PM
bogus's Avatar
bogus
No crank sensors on an L98...
but I like the knock sensor idea...
Old Jan 10, 2005 | 01:57 PM
85blkrose's Avatar
85blkrose
gapped my plugs at .045 and have my timming @ 10* and it runs great. i have a high output coil and module. check out the esc on the side of the ac inlet on the pass side or the knock sensor.
Old Jan 10, 2005 | 02:15 PM
19corvette91's Avatar
19corvette91
maybe he means the reluctor ring in the distrib.......kinda acts like an archaic crank sensor when you think about it
Old Jan 10, 2005 | 04:21 PM
Muffin's Avatar
Muffin
Since it wsn't mentioned I assume no codes are being set. Strange if not. Does the SES light come on at start up? I suggest you pull whatever codes may be set,assuming the SES works. Next make sure your knock sensor is present and connected. Then check the connection of the ESC module. My kneejerk guess is one of these latter two are not doing their job.
Old Jan 10, 2005 | 04:55 PM
bogus's Avatar
bogus
yes, that would work in much the same way.
Old Jan 10, 2005 | 07:41 PM
85 500 horse's Avatar
85 500 horse
If the "crank" sensor is not the problem, I would next check the fallopian tube and the ovary sensor. Every month, they seem to act up in the worst way.
Old Jan 10, 2005 | 08:42 PM
bogus's Avatar
bogus
Old Jan 10, 2005 | 09:07 PM
Frizlefrak's Avatar
Frizlefrak
Speaking from experience?
Old Jan 10, 2005 | 09:32 PM
kcpaz's Avatar
kcpaz
ESC??? SES??? Sorry, I'm brand new to the Corvette/Chevy/Domestic car thing. You have to excuse my ignorance. Not that I'm ignorant about cars....NO! far from it, but when it comes to domestic autos, I feel like a fish out of water sometimes. I do have a repair manual so I guess I could just look it up FYI, I'm running 91 octane, that's as good as it get's in AZ....unless you step it up to 110 race gas (OVERKILL for N/A applications)
Old Jan 11, 2005 | 12:36 AM
bogus's Avatar
bogus
SES = Service Engine Soon light. On the dash is a screen where any number of warnings and such. When you start the car, the SES light should come on. This is done as a self test.
If the light does NOT come on, bet money that the bulb is dead.
If the bulb is dead (or sometimes REMOVED!) then codes won't display.
If the bulb is good, and does not display anything, then there could be deeper problems.
The manual you have, is it the Helms (GM Factory Service manual)? The Chiltons and Haynes are pretty crappy, really. They don't give anything for year specific troubleshooting. If you don't have the Helms, get one - www.helminc.com.
ESC - Electronic Spark Control. This is what controls the knock sensor. If it isn't working right, it will cause all sorts of drivabilty issues.
I hope this helps.
Old Jan 11, 2005 | 09:58 AM
Muffin's Avatar
Muffin
Thanks Bogus. Sometimes I forget everyone on Planet Earth doesn't speak "Corvette".
To 85' Vette Pinging Problem
Old Jan 11, 2005 | 10:24 AM
rick lambert's Avatar
rick lambert
5 years of sitting=alot of condensation in the fuel tank, hope you
used a fuel additive to remove water, Seafoam is a great idea.Don't know about your year specific, but I beleive you need to disconnect the ESC to check your base timing.
Old Jan 11, 2005 | 11:59 AM
redwing76's Avatar
redwing76
Old Jan 11, 2005 | 02:41 PM
Jim Martley2's Avatar
Jim Martley2
One more possiabulity is a plugged EGR passage in the manifold or a non functioning EGR valve itself.
