Wheel question
Old Jan 11, 2005 | 07:38 PM
vetteweiser's Avatar
vetteweiser
St. Jude Donor '03-'04-'05-'06-'07-'08-'09-'10-'13- '14
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Cruise-In VIII Veteran
Default Wheel question
I'm toying with the idea of getting 5 spoke rims for my 93 Ruby. I want the ZR1 style but I'm not sure what size I should get. The ones I found on ebay are 17 X 9 1/2". How will those fit on mine? they also state they are 56mm offset. I have no clue what offset means when it comes to wheels
Anyone have these, will my tires that are currently on my car fit on these wheels? I have stock rims right now (saw blades).
TIA
Old Jan 11, 2005 | 08:13 PM
teebee's Avatar
teebee
2021 C6 of the Year Winner - Unmodified
I can't imagine that these would not fit. Standard wheels for 93 were 8 1/2's in the front and 9 1/2"s in the rear, I believe and the Z07 option had 9 1/2" all the way around, and I believe the proper offset for the 93 would be 56mm.
Are you looking at the OE wheels ZR1's. They are a really good price aren't they? I know several guys here on the forum have bought wheels from them and I haven't heard any complaints.
Old Jan 11, 2005 | 08:16 PM
smack123's Avatar
smack123
I'm looking at the same ones for my 91..... My factory sawblades are 9.5's all around, with 56mm offset. teebee945 is right, your 93 fronts are 8.5, but I believe the wheels you have described would fit perfectly.
Old Jan 11, 2005 | 08:34 PM
C5Jimmy's Avatar
C5Jimmy
I just upgraded to the ZR1 wheels on my '92. I just switched the tires, stock size,(P275/40's) over to the new wheels. That's it for me. The offset is OK, 56mm is the stock offset anyway, so you're ok there. On a '93 though, they went to 17"x8.5" wheels in the front, and the stock tire size in the front was P255/45's) In '92 the wheels were all 17"x9.5" with P275/40's on all 4 wheels, so get 8.5's for the front, or you might need new correct size front tires. ( I'm not a tire size expert!)maybe you could keep the tires you have...So basically, the wheels themselves will fit the car, no problem whatsoever, just a tire size issue in front, and maybe someone else will post an answer for that!
Old Jan 11, 2005 | 08:35 PM
C5Jimmy's Avatar
C5Jimmy
That's where I got mine from...see my corvette photos..no problems with them, and quick shipping and good packaging!
Old Jan 11, 2005 | 08:38 PM
vetteweiser
Cruise-In V Veteran
OE is where I'm looking, and since I live just an hour south of them, and I dont make $60 an hour, it would pay for me to drive there and back to get them. The price is incredible. Hopefully the 8.5" tires will fit on the 9.5" rim. Looking at some website, it seems that it will not be a problem (keeping fingers crossed)
Old Jan 11, 2005 | 08:39 PM
Perfusion's Avatar
Perfusion
TIA
VW,
You should be just fine... Even with 8.5" sawblades up front, it should be a simple R&R (remove and reinstall) for the tireshop with the new wheels.
Old Jan 11, 2005 | 08:41 PM
vetteweiser
Cruise-In V Veteran
Originally Posted by Perfusion
VW,
Wooo HOOO!!!!! Happy Birthday to me!!!! (its next week, I figure my cat would want me to have them, so its her gift to me )
Old Jan 11, 2005 | 08:46 PM
Torch Red's Avatar
Torch Red
St. Jude Donor '09
VW,
I agree ... you likely have at least 255 mm wide tires in front ... they will work on the 9.5 inch wide wheel.
They would look killer on your Ruby ... Personally, I would go for the fat ones (11" wheels out back) but you would need wider tires for those wheels.
Good luck Bra ... and be sure to post some finished pics!
C5Jimmy's Avatar
C5Jimmy
One thing, I don't know what you're plans are for the original rims, but I kept mine, and wrapped them up in the boxes that the OE wheels came in, and they're sittin' in my attic for safekeeping! Just a suggestion...
Old Jan 11, 2005 | 08:47 PM
Torch Red's Avatar
Torch Red
St. Jude Donor '09
Yeah, I also have a couple sets of SB stored away too ... anyone want to buy them and the like new goodyears on them?
Let me know peeps!
Old Jan 11, 2005 | 08:48 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
Be careful with the 255 tire on the 9.5 rim. If you get too close to a curb, you will hit rim rather than rubber. Ideally for a 9.5 rim, you want at least a 275 tire, it gives a little more of a bulge.
vetteweiser
Cruise-In V Veteran
I'll hold on to them for a bit, or put them up in C4 parts. This is all Kara's fault too for asking for exterior mods on her vette. I thought of wheels, now look what I'm doing
Old Jan 11, 2005 | 08:49 PM
vetteweiser
Cruise-In V Veteran
I've only hit a curb once, so hopefully I'll be fine. When the fronts need replacing, I'll definatly get the wider tire
Old Jan 11, 2005 | 09:10 PM
kwik_ta's Avatar
kwik_ta
From: St. Peters MO Sometimes you have to prove yourself by doing alot of killing or alot of dying...
You have the same measurement 9½ in the rear already. the 9½'s on all 4 corners looks tough
Old Jan 11, 2005 | 10:18 PM
vetteweiser
Cruise-In V Veteran
tough as in good tough, or bad tough??
I'm assuming good tough
Old Jan 11, 2005 | 11:34 PM
jerseyvette's Avatar
jerseyvette
VW, got the same wheels about 7 months ago. They've held up great (except for the one I used a brake dust cleaner on...long story short...don't use brake dust cleaner on your new wheels...just soap and water...and I put a coat of wax on them which helps keep the brake dust to a minimum). Totally changed the look of my car and I LOVE them. Here's a pic
To Wheel question
Old Jan 11, 2005 | 11:35 PM
teebee's Avatar
teebee
Vetteweiser, even though you live close and would go and pick them up, it seems that I have read that they still charge you most, if not all the shipping charges.
By the way, happy birthday, my birthday is tomorrow.
Old Jan 11, 2005 | 11:37 PM
Hogan's Avatar
Hogan
From: First to Sign Grumpy's Hat Only 53 miles from Hell
St. Jude Donor '06-'09-'10-'11
Are the center caps the same as the OEM's??? If so, it would be kewl to use the Ruby center cap.
Old Jan 12, 2005 | 02:19 AM
vetteweiser
Cruise-In V Veteran
Thats interesting. I wonder how they would justify the shipping charge? I plan on calling them tomorrow to see if a phone deal is better than the ebay deal.
