Voltage Help
Old Jan 18, 2005 | 04:48 PM
White Six Speed's Avatar
White Six Speed
Default Voltage Help
I just put a new battery in. When I first start her up my voltage is 15.0 and after a few minutes it go's down to 14.9 then to 14.1 then back to around 14.4 and moves around a little bit. Is this normal or is something going bad? I do not know much but i thought it should not go up to 15.0
Old Jan 18, 2005 | 04:52 PM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Sounds pretty normal.
The usual stabilized voltage (no load) is around 13.5 +- .5V.
Mine occaisonally goes to 17V (on the analog gage) when I first fire it up. But, just how accurate are these gages anyway?
Larry
code5coupe
Old Jan 18, 2005 | 05:40 PM
drvn2fast's Avatar
drvn2fast
it should settle right back in to where it should be.
Old Jan 18, 2005 | 07:52 PM
redwing76's Avatar
redwing76
Larry
code5coupe
I agree with this Dude!
Old Jan 18, 2005 | 08:33 PM
Jet-Jock's Avatar
Jet-Jock
Check the connections, torque to 15Nm.
To Voltage Help
