Camera mount options
Old Jan 25, 2005 | 10:47 AM
Nathan Plemons's Avatar
Nathan Plemons
Default Camera mount options
Other than the cross brace or a complete roll cage, what kind of camera mounting solutions are there for C4's.
I don't really need the cross bar for safety / stiffness, it would just be in my way most of the time.
Old Jan 25, 2005 | 11:46 AM
VFR750's Avatar
VFR750
I've used the helmet camera for my motorcycle (mounted on the bike) and for bicycling (on my helmet) and it works very well. I have plans to try it out on the Corvette this Summer. It's lightweight and uses a very sticky Velcro to mount. You can put it someplace where it catches part of the car or just the road. I suppose you could put it someplace inside the car, too, if that's what you're after. It also comes with a microphone which can be mounted someplace different from the camera. This is good since the camera is often out in the wind.
http://www.helmetcamera.com
Old Jan 25, 2005 | 12:13 PM
Red_Vette_93's Avatar
Red_Vette_93
don't know if you have a coupe but you might try where the top bolts down if you do.
Old Jan 25, 2005 | 02:23 PM
MinnesotaWhite's Avatar
MinnesotaWhite
Hey Nathan...I know you are a handy guy, so I'll give you my solution.
Used a product called "Ram Mounts" http://www.ram-mount.com/ and the only bolt in the rear of the car, the bolt that holds the targa-top storage bracket.
Basically, there is 1 bolt with 1 nut under that plastic cover, so I used some steel an did a very crude, but functional L just short enough to hide under the cover.
Then I used a ball mount from RAM, cut a small notch in the plastic, and mounted the ball to the L and put the cover over all of it...so you only see a ball sticking out of the plastic cover.
This is the RAM mount I use. http://www.ram-mount.com/drawings/rama101.jpg
One side is permanently mounted to the car, and the ball mount on the other side of the locking arm is mounted to the camera.
Now all my video is from the passenger side, but you still get good video from there. Drag racing the camera doesn't shake at all...but I've been on a couple of tracks in which the surface was rough and it shook the camera...so I used a little foam and pressed the camera against the pillar to keep it from shaking.
You'll find the RAM mounts incredibly strong, and really easy to use. I can mount the camera in about 20 seconds, and pull it out in about 5.
I'd show you pics, but the car is in storage sleeping for the winter. If you have any questions, shoot me a note.
Oh...here's a video using the mount. All in-car shots are using this setup.
(14 meg)
http://www.boosperformance.com/rock_falls_2004_high.wmv
Old Jan 25, 2005 | 03:50 PM
Red_Vette_93
cool video, looks good.
Old Jan 25, 2005 | 07:38 PM
bogus's Avatar
bogus
Why does the phrase, "Duct tape the damned thing to the dash", keep running through my head?
Old Jan 25, 2005 | 08:01 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
Nathan, look for Warren S he made a bracket that attaches where the rearview mirror is. I look for the email he sent me on it and forward it to you.
Old Jan 25, 2005 | 08:04 PM
Mr. Peabody's Avatar
Mr. Peabody
C4 of Year Finalist (appearance mods) 2019
Whew that was a video. Good thing my connection here at work has lots-o-bandwith.
Old Jan 25, 2005 | 08:18 PM
Mr Mojo's Avatar
Mr Mojo
Nathan, here you go
http://community.webshots.com/album/102276848UPNpsc/1
He had a write up on it somewhere, but the pics should definitely help out.
Old Jan 25, 2005 | 09:03 PM
Nathan Plemons
I taped it to my passenger side head rest last time! That's what I'm trying to avoid.
Old Jan 25, 2005 | 09:19 PM
Nathan Plemons
Originally Posted by Mr Mojo
Nathan, here you go
That would probably work, but not with the dimensions given. My camera is much bigger than that, being a true video camera instead of a still camera with some video capability.
Old Jan 25, 2005 | 09:26 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
I made one out of some scrap wood. It has a pessure fit between the plastic rigde behind the b pillar and the plastic groove behind. It works great at the strip and the road course. Painted it with black marbleized paint from the deopt (paint was the most expensive part at $8). I can shoot you some pics, I don't have a host to post them here currently...
Old Jan 25, 2005 | 09:37 PM
Mr Mojo's Avatar
Mr Mojo
You can adjust the measurements accordingly.
Old Jan 25, 2005 | 10:05 PM
Nathan Plemons
Naturally. I'd draw the whole thing up on the computer first. In fact I might could even rapid prototype a plastic mock up.
C4DC, yes please send me some pictures of your solution. Nathan.Plemons@wku.edu
Old Jan 25, 2005 | 10:27 PM
Mr Mojo's Avatar
Mr Mojo
Arisa also used a regular camera tripod in his. He put two of the legs behind the seats and the third in the hatch. I don't recall how he secured it, but it seemed to work for him. He also ran a microphone to the exhaust to get maximum sound(or noise).
Old Jan 25, 2005 | 11:15 PM
C4DC's Avatar
C4DC
St. Jude Donor '06
Nathan I sent you 4 pics. Let me know if you get all 4, the upload was erratic...
Old Jan 25, 2005 | 11:20 PM
bogus's Avatar
bogus
and what a glorious sound that is... damn that car sounds like a big block.
Have you stalled it lately?
To Camera mount options
Old Jan 26, 2005 | 01:27 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Something tells me you and Jesse James wouldn't get along.
Old Jan 26, 2005 | 08:35 AM
runner140*'s Avatar
runner140*
Default Nathan....
Just installed a "Harness bar" the type from Arizona speed & marine.
It installs with the stock equipment and used for racing harnesses, camera mount and fire extinguisher. Got mine used and love it. It also firms up the ride (reduces flex).
Old Jan 26, 2005 | 11:31 AM
Mr. Magoo's Avatar
Mr. Magoo
From: Damn taxes! Pimpin' Ain't Easy in Massachusetts
2018 C4 of Year Finalist
St. Jude Donor '03-'04-'08-'09
Same here it works great, real good for Auto-X races.
