When a tach does this
Jan 26, 2005 | 03:46 PM
From: No more yankee my wankee, the Donger is tired!
I assume it's not good. Any ideas on the fix? With engine not running it's at rest at 0, when running it pegs off the scale.
Jan 26, 2005 | 03:50 PM
most likely culprit is a bad ground associated with tach filter, or fail(ing) tach filter itself.
Jan 26, 2005 | 04:14 PM
with bad ground.
Jan 27, 2005 | 01:12 AM
This is just the excuse you need to convince the wife to get the new C6. You just need to say, "Honey, the repair will be in the thousands and it just makes fiscal sense to get a new one."
Jan 27, 2005 | 01:27 AM
Unless you have a modified ZR-1, like Jeff has...
Which makes me think Jeff, did you wind it up that high and get it stuck there?!
Jan 27, 2005 | 02:37 AM
Not my car, it's only got a 6K tach...
It's on a 90 L98 car, don't have much experience with them.
Jan 27, 2005 | 03:48 AM
Dah I didn't even think about that...
Well anyway good luck with that fix!
Jan 27, 2005 | 07:26 AM
St. Jude Donor '03-'04-'06-'08-'09
looks like your out of fuel
Jan 27, 2005 | 07:38 AM
What was you speed.....
What was your speed when you stuck the tach at 7+ ?
