85 L98 timing info needed
Old Jan 26, 2005 | 07:00 PM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
Default 85 L98 timing info needed
Could someone please let me know what my 85 L98 timing is supposed to be set at? Also, does anybody know where I can get the emissions information sticker that goes on the radiator shroud? Mine is missing and that's where the timing info is located. Even my Helms says to "check the sticker" This sticker has been discontinued since 1993 and I've already tried Eckler's, MAM, Corvette Central, Zip, and the Paddock. Surely somebody reproduces these. If I am totally out of luck could someone copy the info and email it to me? Thanks in advance.
Old Jan 26, 2005 | 07:02 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I run my 88 at 8 deg BTDC, but I have removed the precats and I gap my plugs at .050
I think factory is 6 deg BFTDC
Someone will be along in a minute to comment
Jack
Old Jan 26, 2005 | 07:17 PM
JAKE's Avatar
JAKE
6 degrees Before Top Dead Center (BTDC) is the stock spec.
That's checked with the engine idling and the EST wire disconnected.
That wire should be a black wire with a tan stripe located near the power brake boost. Somewhere under the booster between the booster and the block.
After reconnecting the EST (DISCONNECT AND RE-CONNECT THE EST WIRE WITH ENGINE AND THE IGNITION KEY "OFF"), you'll need to disconnect the battery for about 20 seconds to clear the error code that gets set when the computer detects the engine running with the EST disconnected.
Can't help with finding a sticker.
Jake
Hope this helps.
Old Jan 26, 2005 | 09:30 PM
JCAIRE2's Avatar
JCAIRE2
Jake
Hope this helps.
Old Jan 26, 2005 | 09:42 PM
mikey whipreck's Avatar
mikey whipreck
Do you think the NCM might have hard to find stickers like that?
Have you checked with your local dealership?
And they're right with the timing; the stick on my 85* says 6*BTDC. I actually have mine at 0*
Old Jan 26, 2005 | 10:01 PM
TIMSPEED's Avatar
TIMSPEED
What's the purpose of 0º?
Old Jan 26, 2005 | 11:10 PM
mikey whipreck
Eliminate any chances of pinging.
I disconnected the knock sensor and did not want to run regular timing until I am comfortable with it. I'll eventually bump it back up to 6*
Old Jan 27, 2005 | 09:58 AM
Midnight 85
Thanks to all who replied, I can't believe somebody isn't reproducing these, they've been discontinued since 1993 according to the dealership.
Old Jan 27, 2005 | 11:54 AM
85vet's Avatar
85vet
Cruise-In V Veteran
If you go to Carlisle - there is a vendor that sells reproduced stickers of all kinds. I found a sticker for a friend that went on his 68 driver visor that many said did not exist. I do not know the name of the vendor - maybe someone else will chime in.
Good Luck.
Old Jan 27, 2005 | 02:20 PM
Midnight 85
Corvette Parts Online just responded to my note to them about availability, this sticker is going to be reproduced somewhere around the end of the year.
To 85 L98 timing info needed
