Makeshift cowl induction
Old Mar 29, 2005 | 10:21 AM
  #41
comp's Avatar
comp
probably just cooler under the hood
Old Mar 29, 2005 | 10:45 AM
  #42
JCAIRE2's Avatar
JCAIRE2
Originally Posted by conv90
good idea! I will try it...
What I do not understand is this:
you say " Once I get going on the freeway, it starts acting as a cowl induction deal, and air is rammed in."
How fresh air can go IN the engine bay if the car go in the direction of where the new opening is?
If the opening is in FRONT of the hood...
..I can't understand this cowl induction effect..
-Beppe-
The windshield/hood area is a high pressure zone when moving. The area under the hood is a low pressure zone. The air will be forced into the gap between the hood and windshield, just like on a high-rise cowl induction hood.
Old Mar 29, 2005 | 04:04 PM
  #43
Aardwolf's Avatar
Aardwolf
"The windshield/hood area is a high pressure zone when moving. The area under the hood is a low pressure zone. The air will be forced into the gap between the hood and windshield, just like on a high-rise cowl induction hood."
Is that good, or bad? So air is going down into the hood, air is not coming up out from under the hood? Would this pull in rain to?
Old Mar 29, 2005 | 10:05 PM
  #44
JCAIRE2's Avatar
JCAIRE2
I wouldn't worry about it. How many thousands of cars (camaro, firebird, etc...) are running around with a cowl induction hood. Those older cars with carbs would also have to worry about geting water in the carb if it were a problem.
Not something I would be concerned about at all. I've never heard of anyone with a cowl hood having problems with water entering the engine compartment.
Old Mar 31, 2005 | 06:57 PM
  #45
ClarenceT's Avatar
ClarenceT
Conv90: google it up, but JCAIRE2 said it quite nicely. It's a neat deal. I left SOME stripping just to act as a gutter for when I wash my car, etc so it doesn't always run down the firewall.
Old Apr 1, 2005 | 09:00 AM
  #46
conv90's Avatar
conv90
You conviced me!
the razor blade is on my hands
-Beppe-
Old Apr 1, 2005 | 09:19 AM
  #47
red L98's Avatar
red L98
Originally Posted by comp
what about the wheel well's ????
thats what i did , i took both out cut 3 circle in each one and screend them off and sprayed them black
Old Apr 1, 2005 | 09:26 AM
  #48
red L98's Avatar
red L98
my car has a cowel hood and never had a problem with water , my car stays at 170- 160 all the time and i have a 434 with 11.5 comp
