Missfire when you stomp on it
Old Jan 27, 2005 | 11:30 AM
Bilyk's Avatar
Bilyk
Default Missfire when you stomp on it
I'm not even sure if this is a missfire. Probably an electronic bug of some sort. If you stomp on it from a dead stop or a roll, it seems like a few cylinders will fire, pause, and then rev up normally.
I was thinking maybe something TPS related where it's not getting enough fuel or too much fuel?
Has anyone seen this before?
85 L98
Old Jan 27, 2005 | 11:53 AM
CFI-EFI's Avatar
CFI-EFI
The TPS is easy enough to check.
RACE ON!!!
Old Jan 27, 2005 | 11:55 AM
Bluewasp's Avatar
Bluewasp
NoVa Events Coordinator
St. Jude Donor '14
My LT4 had a similar problem but it would pause, cut out, between 5xxx and 6000 RPM. turned out to be the MAF.
To Missfire when you stomp on it
