another hp/quartermile question
Old Jan 28, 2005 | 10:10 AM
1996man's Avatar
1996man
Default another hp/quartermile question
running about 400rwhp on a C4 with a ZF/3.45 rear end and a redline of around 6700 what do you think a quarter mile time would be with a really good launch. if the ZO6 can do it in almost a flat 12 with 400flywheel hp i think high 11s should be possible wiht the right tires
Old Jan 28, 2005 | 11:00 AM
FD2BLK's Avatar
FD2BLK
If you stick a launch with a set of Slicks then probably mid to low 11's easy. I have went 11.7 with a 1.8 60' and limmited traction so I am hoping for low 11's this year on a good day with good air. It will be interesting
Old Jan 28, 2005 | 07:18 PM
1996man's Avatar
1996man
awesome! any other thoughts?
Old Jan 28, 2005 | 07:24 PM
chriswtx's Avatar
chriswtx
Get some stick tires. I'm in the same boat. Running street tires I can't hook up for the launch or 1st-2nd shift and 2nd to 3rd shift...My mph is good enough for a low 11 sec time. Just need some tires.
Old Jan 28, 2005 | 08:07 PM
C4Tom's Avatar
C4Tom
3rd Gear
Best traction i have had on street tires is with Kuhmo tires, they stick.
Old Jan 30, 2005 | 11:09 AM
1996man's Avatar
1996man
mid 11s would be nice
Old Jan 30, 2005 | 12:32 PM
comp's Avatar
comp
Old Jan 30, 2005 | 01:02 PM
LD85's Avatar
LD85
1996man, you got an auto or stick,,, if a stick what RPM do you shift?
I am changing over to 3.45's as we speak, hoping to help the ZF out a little, anything 11's is OK for me.
Old Jan 30, 2005 | 01:27 PM
1996man's Avatar
1996man
i said in my first post it was a ZF(6 speed manual) I am not amking this kind of power yet. i am mostly stock right now so i shift about 6300rpm. but after my cam swap and engine rebuild next spring i should be shifting around 6700.
Old Jan 30, 2005 | 02:59 PM
LD85's Avatar
LD85
I missd the ZF part, I guess I will know about shift points before you do, as soon as the track is open, I'll be on my way.
Good luck!
To another hp/quartermile question
