radiator replacement, how too,
Old Jan 28, 2005 | 05:59 PM
guywade's Avatar
guywade
Default radiator replacement, how too,
first time on a c 4 for me, , i'm installing a becool dewitt radiator, take off, air cleaner assembly and tube to throttle body, , then what, any pictures, any easy ways out there to save time, and trouble, i know i need to cut back the top rubber holders to fit the larger radiator, thats friends GUy
Old Jan 28, 2005 | 06:36 PM
bogus's Avatar
bogus
its not hard.
drain all coolant into a catch bin...
remove all the screws that hold the cover in place, and there are a lot!!!
Is this an automatic? remove the lines to the rad from the transmission. If the new rad does not have a tranny cooler built in, you will have to get stand alone unit.
remove the cover and remove the radiator.
Old Jan 28, 2005 | 06:42 PM
CFI-EFI's Avatar
CFI-EFI
Lefty loosy...Righty tighty.
RACE ON!!!
Old Jan 28, 2005 | 06:50 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
Originally Posted by bogus
its not hard.
There are several very small and very well hidden screws, have patience. It is really very easy, just take your time
seeya
Old Jan 28, 2005 | 09:30 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Trade me for my oem radiator, then I'll show you how to install it.
I just started taking unscrewing stuff and found it to be really easy. As mentioned, make sure you get all those screws out, there was 2 that i missed and decided to double check before breaking the shroud.
Old Jan 28, 2005 | 11:35 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
https://www.corvetteforum.com/techti...D=53&TopicID=2
Old Jan 31, 2005 | 02:38 PM
guywade's Avatar
guywade
thanks everyone, i 'll get going now!
Old Jan 31, 2005 | 02:39 PM
guywade's Avatar
guywade
gee ok, lol!
To radiator replacement, how too,
