Mat Sensor
Old Jan 29, 2005 | 09:05 PM
LoneStarSoldier's Avatar
LoneStarSoldier
Default Mat Sensor
I've looked in my manuals and can't find out where the MAT (Intake Air Temperture) Sensor is located. I'm pretty sure it's on the plentum, but do not know where. Can anyone give me a hand??????????
HAVE A GREAT DAY!!!!!!!!!
Old Jan 29, 2005 | 09:35 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The MAT sensor is located under the rear of the plenum.
Old Jan 30, 2005 | 09:56 AM
LoneStarSoldier
ttt
Old Jan 30, 2005 | 06:40 PM
LoneStarSoldier
Can someone be a little more explicit on the location of the MAT sensor. Appreciate your help.
Old Jan 30, 2005 | 07:27 PM
JAKE's Avatar
JAKE
I don't know if GM moved it around in different years, but on the 86 it's in the center of the plenum's underside, all the way back toward the disributor.
It's kind of hard to see, but if you stand on the passenger side of the engine, look over or around the fuel pressure regulator you can just see it sticking down from the plenum. In any case you should be able to see the connections wire.
Jake
To Mat Sensor
