St. Jude Donor '06-'07-'08-'09-'10-'11-'12-'13-'14-'15-'16
Antenna sticking
I have a racoon tail on my C4's antenna. Every time I turn the Bose off or shut the car down the antenna goes down and sucks the tail down the little hole. What can I do to prevent this?
Edit: Gotta confess, saw this on another very odd forum and stole the idea. Hey, its dang cold out here in Michigan and there is no football on TV. Gotta do something to prevent cabin fever!
That's the beauty of the situation. Pulling the tail out of the little hole will PREVENT you from a case of cabin fever. Good luck and keep practicing ,you will get it right after a while .
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
I tied a racoon tail to my antennae, but the doggone thing kept scratching the paint when I lowered him back down to the rear deck
I found out that it's not good to set anything over top of the antenna hole (like a rolled up car cover). I cranked the engine and the antenna, with some degree of power, pushed the car cover out of the way. -- Eric
If you are serious you can take apart your motor and try to modify the down switch to open sooner. When the antenna is going up the DK GRN wire is the hot and the GRY wire is the ground. When the antenna is going down the DK GRN wire is the grounded and the WHT gets the voltage.
Go to www.domesticmisfits.com
They have a C4 section AND a BABE section!!
You will probably recognize some of the more ourtageous guys from this forum there.
