hheellpp does this thing come apart?
Old Jan 30, 2005 | 04:30 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
Default hheellpp does this thing come apart?
i'm trying to pull the wire harness out of my 90 so i won't have it in the way or hanging loose. does this come apart or is it just for passing through a bulkhead? the heater/ac box is next to it. thanx
Old Jan 30, 2005 | 04:38 PM
91whitevert's Avatar
91whitevert
should unplug 4 or 5 conectors under dash kick panal pasenger side
If the same as 96'
Old Jan 30, 2005 | 04:47 PM
Sleazy Rider
thanks for the info 91whitevert, i'll head that way. was going to pull that side anyway before taking to painter.
91whitevert, thanks for the tip. 4 electrical and 1 vacuum, pulled right through. thanx
Old Feb 2, 2005 | 01:03 AM
gcrouse's Avatar
gcrouse
Look on the outside face of the connector; in the middle of all the wires is a screw holding it together.
There may also be a plastic clippy thing or two along the edge; but those 2 halves will separate.
To hheellpp does this thing come apart?
