Relocate battery article??
Old Jan 31, 2005 | 11:19 AM
LT70ZR91's Avatar
LT70ZR91
Default Relocate battery article??
Some time ago there someone posted some pictures relocating the battery under their c4 behind the rear axle on the cross member. I had it saved but have since had computer problems and have lost them. Does anyone have any knowledge of where I can find any of this information?
Old Jan 31, 2005 | 01:53 PM
NitrousSam's Avatar
NitrousSam
This interests me also. Weight transfer would be better in the back for sure.
Old Jan 31, 2005 | 01:59 PM
Sleazy Rider's Avatar
Sleazy Rider
Veteran: Marine Corps
arn, i am going to put a fuel cell back there and am going to heliarc a couple cross braces under neath and between the frame to mount it. could also mount a battery box as well. jus a thought
Old Jan 31, 2005 | 05:05 PM
Flame Red's Avatar
Flame Red
I used to have a tech tip posted to relocate the battery to the storage compartment behind the pass seat. It is no longer posted in the tech tip section I see.
Basically, I found that a Optima Red top fit perfectly back there. Used a basic battery tray, and new hold downs. Ran LARGE gauge battery cable back to the old location. Found a marine battery post that was insulated so I could attach the original battery cable to the new cable witout modifing the original cable. For ground, I ran a short cable back to the frame. I even found a large 150 amp circuit breaker that makes it really easy to disconnect the battery by flipping a switch.
Just make sure you get clean firm connections and it works great.
Old Feb 1, 2005 | 02:51 PM
LT70ZR91's Avatar
LT70ZR91
ttt
Old Feb 2, 2005 | 12:55 AM
gcrouse's Avatar
gcrouse
I don't remember writing an article, but here's a couple pics of my rear mounted Optima battery. Basically a couple metal trays from PepBoys, threaded rod, and a guy to weld the upper tray to the rear X-member (leave space for the fuel lines). Got a heavy 0-gauge wiring kit from Summit and ran it to the starter.
Old Feb 2, 2005 | 01:43 AM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Exotic Muscle makes a kit for putting in the rear storage compartment.
To Relocate battery article??
