need advice
Old Jan 30, 2005 | 08:08 PM
lucky85's Avatar
lucky85
Default need advice
which would be better
A late model vortec roller motor w/ a vortec tpi intake stock otherwise or....A bonestock 400 w/a comp xe256-12 and a stock tpi manifold Just looking to get this thing running.BTW I have both setups in my shop also which would require less tuning if any at all
Old Jan 30, 2005 | 08:16 PM
CFI-EFI's Avatar
CFI-EFI
There is no substitute for cubic inches. Since you already own both, put the good top end on top of the 400. You had to ask???
RACE ON!!!
Old Jan 30, 2005 | 08:32 PM
lucky85's Avatar
lucky85
Will the vortec heads go on the 400 along with the roller setup
Old Jan 30, 2005 | 08:45 PM
CFI-EFI's Avatar
CFI-EFI
As far as heads fitting, a small block is a small block. The 400 can be converted to take factory roller cam parts, with an OE lifter change, or you can use a retro roller set up. For less money you can retain the flat tappet cam in the 400.
RACE ON!!!
To need advice
