Best CAT position w/ Long Tubes?
Old Feb 3, 2005 | 03:10 PM
sothpaw2's Avatar
sothpaw2
Default Best CAT position w/ Long Tubes?
Haven't seen much said here on this so thought I'd ask:
With a header install, where (for LT1 cars), the cat has to be moved and has to be a new bullet style cat, what is the best position for the new cat for peak engine power/torque?
I was talking to 94STL and he is thinking it's best to put the cat right at the collector, not further back. It makes an easier install, I'd think, so I'm inclined to go that way.
Any opinions? Anyone try different ways (perhaps by accident?)
Old Feb 3, 2005 | 03:12 PM
Nathan Plemons's Avatar
Nathan Plemons
Well the BEST position for maximum power is to leave the cat on the shelf. However, a performance cat won't rob you much if any horsepower. For a cat to work it must be at a certain temperature, so you'll want to keep it as far forward as possible. This would out real well since that's where you have the most room.
Old Feb 3, 2005 | 04:00 PM
bogus's Avatar
bogus
I am waiting for LTs to include a cat in the collector... that would rock.
Old Feb 3, 2005 | 04:11 PM
1992B4C's Avatar
1992B4C
I did the same thing that this guy did:
(pictures of Greg's exhaust)
http://temp.corvetteforum.net/c4/gcr...t/exhaust.html
(Greg's home page)
http://temp.corvetteforum.net/c4/gcrouse/
Old Feb 3, 2005 | 04:13 PM
Lichen's Avatar
Lichen
If you have an A4, you're pretty much stuck with putting them behind the transmission.
Old Feb 3, 2005 | 04:24 PM
Perfusion's Avatar
Perfusion
Whereas with a ZF6, they go quite nicely just after the collector...
Old Feb 3, 2005 | 05:31 PM
FELNGR8's Avatar
FELNGR8
What he said.
Old Feb 3, 2005 | 06:07 PM
bogus's Avatar
bogus
on the ZF6, it's very close to the stock location.
To Best CAT position w/ Long Tubes?
