white smoke!!!!!!!!!!
Old Feb 3, 2005 | 05:05 PM
dsnell1004's Avatar
dsnell1004
Default white smoke!!!!!!!!!!
when the car sits for a few days I get a cloud of white billowing smoke comming from behind the distibutor . I try to look behind their but just can't see. after the car warms up it stops. where could this be from?
Old Feb 3, 2005 | 05:41 PM
Strike3's Avatar
Strike3
Just a guess, but it sounds like possably an oil leak around the oil pressure sensor or the infamous rear intake leak. I'm thinking the oil drips, or runs,onto the exhaust pipes on either side of the transmission while the car sets. Then when started, the pipes heat up, the resulting smoke follows the transmission tunnel to the rear of the engine and distributor area.
While your driving or using the car frequently, the oil is burned off as it drips, therefore does not accumulate.
As I said, Just a guess.
Good Luck.
vader86's Avatar
vader86
Probably a leak at the rear main seal thats getting burnt.
Thats what it was in my case.
Old Feb 3, 2005 | 06:05 PM
dsnell1004's Avatar
dsnell1004
i think it maybe rear main seal also but when I look under the car, I also see a couple of anifreeze spots on the ground right around the same area????.
Old Feb 3, 2005 | 06:18 PM
Pete K's Avatar
Pete K
With the engine off and cold, pressure test cooling system. This will quickly and easily tell you where your problem is.
To white smoke!!!!!!!!!!
