obd2 system for 93 lt1 vette
Old Feb 3, 2005 | 06:16 PM
corvettejoe's Avatar
corvettejoe
7th Gear
Default obd2 system for 93 lt1 vette
i'm looking for a system to run in obd2 not obd1. also where do i get harness for gauges, would like to run coil packs also. thanks joe
Old Feb 4, 2005 | 02:44 AM
tjwong's Avatar
tjwong
You can find a OBD2 harness from a 96 C4, but you would have to change the early Opti unit to a late model unit and add a crank sensor and a reluctor wheel. And add another set of O2s into your exhaust.
Why do you want to change to a OBD2 system?? It would be more do-able to change to a 95 PCM and the associated hardware.
Old Feb 4, 2005 | 06:13 AM
93 ragtop's Avatar
93 ragtop
Also keep in mind that the 93 is speed density and 94 up is MAF so that would have to be added as well.
To obd2 system for 93 lt1 vette
