I am starting to get tired of these hondas buzzing around town. And I've been looking for some excuses to do something big performance-wise. Not only get the power I've been wanting but also be able to leave honda kids with their mouths hanging open.....I am leaning towards all motor and would like to eventually stroke my LT1 out. But my problem is should I go to 383 or to 396? If you know power diffs and/or any other related things please share.
Very satisfied with my 383. I did not build a 396 due to budget reasons. Not possible to build a "cheap" 396. All parts of the rotating assembly are first rate. I also could not afford to buy an aftermarket oil pan. My oem pan worked with 383. You cannot go wrong with either. If you plan to buy good stuff do the 396. If money gets tighter there are more options with the 383(parts wise)
Jim
I went with a 396, the block did need more clearing than a 383 but I am hoping that the torque over the 383 will be worth it. All the problems I'm having with mine are from my inexperience in doing the work myself. And no...I did not build the short block, I had it built by HPE in Houston. They do really good quality work. Either way you cant go wrong.
I have to agree with the cost factor if dollas are not a factor due the 396 Im 100% satified with the power this thing gives me have not dynoed yet for still working out the bugs and misc tweaks that need to be done. All bs aside if I had to do it again Id prob buy another car already done chasing down all the parts I needed and tuning and etc was a PIA and downtime nearly broke me spirit and pocket wise...
I started out going the 383 route, but as it turned out it is now a 385.
I suggest figuring out what you want to do with the car (street, strip, ax, road race, etc) and build accordingly. I chose the smaller displacement and am very happy with the way mine turned out. See sig for modifications...
I am of the school that tuning can make a huge difference. The only thing is a perfectly tuned 396 should make more power than a 383 with the same tuning. about 3% more or so.
uuh I beg to differ,
remember the bigger the stroke, the more important that good heads are used. If money s not a factor, Id go 409 since the crank and pistons/machinework won't be much different. but If cash is an issue 383 parts are much cheaper due to the availibility. I went with 383 for my turbo motor but in retrospect I would have stayed 355 and spent the money else where ($1800 in machinework).
Does anyone know how much clearancing work is needed to get a 4" crank into our LTx blocks? How much more versus a 383 or 396?
It depends on if your doing "H" or "I" beam rods. A small base circle cam is in order as well as an additional .062 compared to a 396 in the pan rail Your gonna need a clearenced pan and Might have some issues clearing the oil pump. To take care of cylinder filling on a 409 you better have heads in the 300cfm range and around 215cc's or your gonna have a motor that will fall flat on it's face by 4500. Great for towing, not great for eating Rice.
I was thinking Lunati Pro-Mod rods. I think the GM847 cam is considered a small base circle cam - correct? Also, anyone know if a 409 would withstand 12-14 psi in a supercharged application (centrifugal blower)?
Wouldn't a 383 rev faster than a 409 to build boost better?
If one could build a 409 to live under this blown application, any
drawbacks? Any need to use block fill or anything like that?
If you use the Lunati Pro-mods you do not have to use a small circle base cam. They will clear a regular cam. The 847 is a normal cam.
This is my setup. I'm using 6 inch rods though, and if you do a 396, you'll want to use shorter rods. With my rods the wrist pin is well up into the piston (not a good thing with a blower).
Do I understand you correctly? I can keep my GMHot cam and go with a 396 stroker??
Yes, but I think you will be a little dissapointed. I did that when I first did a 396 and though the low end torque improved greatly the peak hp did not (about 10hp gain peak). I think the Hot Cam is a little small for a stroker motor.
Strokers can "absorb" quite a bit of cam timing-Spoke to the owner (can't remember his name) of Golen this morning, he quote 396 shortblocks starting in the low-mid $3000 range. He was very informative.
