Synthetic Power Steering Fluid ????
Old Feb 4, 2005 | 09:34 PM
AGENT 86's Avatar
AGENT 86
Active Streak: 90 Days
Default Synthetic Power Steering Fluid ????
Who makes a 100% synthetic power steering fluid ??
Old Feb 4, 2005 | 09:48 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
I'm using some and I think it's Royal Purple? My speed shop guy recommended it and it's been in for some time with good results.
Old Feb 4, 2005 | 09:53 PM
Pete K's Avatar
Pete K
Not positive but I think Amzoil does.
Old Feb 4, 2005 | 10:02 PM
AGENT 86's Avatar
AGENT 86
So far all i have found is a Valvoline synthetic blend. Nothing in my town. I'll have to let my fingers do the walking tomorrow.
Old Feb 4, 2005 | 10:04 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Mobil 1 ATF you dummy! That's what I use.
Old Feb 4, 2005 | 10:18 PM
C4Crazy787's Avatar
C4Crazy787
How long have you been use it as PS fluid??
I was thinking about using it in the PS, already use it in my transmission.
Old Feb 4, 2005 | 10:24 PM
Corvette Kid
I'm not saying it'll hurt anything, many cars come with ATF in the P/S but when they recommend a special fluid, such as power steering fluid, I prefer to remain with that.
Old Feb 4, 2005 | 10:41 PM
CentralCoaster
It's all the same except for the red die.
Old Feb 4, 2005 | 10:49 PM
Corvette Kid
I'm not so sure. I've worked on some systems that state that you are absolutely not to use ATF.
Old Feb 4, 2005 | 10:54 PM
CentralCoaster
I've searched for the chemistry on these things, and can't find crap for info.
Old Feb 4, 2005 | 11:07 PM
Corvette Kid
I would think that the main differences would be in additives, etc. A lot of the stuff I've worked on over the years has been HD trucks and such. In KWs, for example, ATF has always been the factory fill. Internationals have most generally used and only recommend the clear P/steering fluid. I'd be curious to know more about it too.
Old Feb 4, 2005 | 11:29 PM
AGENT 86's Avatar
AGENT 86
Iv'e used ATF for power steering fluid for the last 29 years. Why does owning a vette change my way of thinking.
Are their better additives and conditioners in the power steering version ??
Or is it lacking color ??
Old Feb 4, 2005 | 11:52 PM
froggy47's Avatar
froggy47
Red Line P/s Fluid, just put it in, works fine
Old Feb 5, 2005 | 05:55 PM
k99ja04's Avatar
k99ja04
Hydraulic clutch fluid is basically DOT3 brake fluid with anti-squeak additives. I also agree the chemistry is impossible to find. As an organic chemist I would find the actual chemical components interesting. Most corporations are loathe to release proprietary information. Unless it was fit for human consumption, then they would have to disclose that info per FDA regs. I wouldn't recommend anyone go slug a bottle of power steering fluid though!
I would imagine the major difference between the types of fluids recommended for a specific application is the viscosity at various thermal levels. For example your transmission will see more heat than your hydraulic braking lines, so needs to maintain a certain viscosity for a given amount of heat.
For your trivia buffs out there did you know the prefered unit of measurement for liquid viscosity is the poise, most commonly in the magnitude of centi-poise (pronounced like combination of 'poison' and 'eazy').
Old Feb 5, 2005 | 06:02 PM
dynalead's Avatar
dynalead
Redline Power Steering fluid. I have been using it in the P/S system of my race car (C-4 rack) for years. A quality fluid.
Good luck.
Old Feb 5, 2005 | 08:36 PM
AGENT 86's Avatar
AGENT 86
Thanks everyone
To Synthetic Power Steering Fluid ????
