how to set int timing?
Old Feb 5, 2005 | 10:47 AM
devilfish's Avatar
devilfish
Default how to set int timing?
Does this work?
Set the damper at 8 degrees using the timing tab. Then use a mulimeter on the no1 "pin" on the dis cap, use the other wire on the rotor tip. And then turn the dis cap until you got a "short" notification on the mulitimeter.
Just a thougt
Old Feb 6, 2005 | 12:30 AM
C4396roadster's Avatar
C4396roadster
did you disconnect the single wire near the mastercyl and brake booster its a single wire thats connected with a weatherpak connector?
Old Feb 6, 2005 | 05:36 AM
MaxLean's Avatar
MaxLean
Originally Posted by devilfish
Does this work?
Just a thougt
That wouldn't work as there is no actual connection from the rotor tip to the terminals. There is an air gap that the spark must jump. A good way to set the initial timing when installing the distributor is to align the timing marks on the ballancer to 8 degrees (or whatever initial is supposed to be) making sure that your on true TDC for #1 and not it's exhaust stroke. Put the cap on the distributor and make a mark on the base just below the cap where #1 tower is. Then simply install the distributor and make sure that the rotor is aligned with the mark you made on the distributor body. This should get you very close for initial start up. After you get it running, disconnect the single wire timing connector and set the timing with a timing light. Shut off the engine, reconnect the timing connector, and you're done!
Old Feb 6, 2005 | 12:09 PM
96dblblack's Avatar
96dblblack
Originally Posted by MaxLean
That wouldn't work as there is no actual connection from the rotor tip to the terminals. There is an air gap that the spark must jump. A good way to set the initial timing when installing the distributor is to align the timing marks on the ballancer to 8 degrees (or whatever initial is supposed to be) making sure that your on true TDC for #1 and not it's exhaust stroke. Put the cap on the distributor and make a mark on the base just below the cap where #1 tower is. Then simply install the distributor and make sure that the rotor is aligned with the mark you made on the distributor body. This should get you very close for initial start up. After you get it running, disconnect the single wire timing connector and set the timing with a timing light. Shout off the engine, reconnect the timing connector, and you're done!
Could not have said it better my self.
To how to set int timing?
