Battery gurus step inside
I left on trickle charge last night (2 amp) and it the charger indicates it is almost back to full charge.
Question. Assuming it starts, will the battery be trustable (word?) or should I replace it? It's only 25 months old.
You did not mention how long long your car had been sitting. I'm just wondering if you have a severe drain on your battery while sitting. You can do this with a DVM and go between the battery and the battery cable and check the current drain.
I'm no "guru" just trying to help out.
2)Sounds like what you did was just let it sit too long without charging it...a drain is normal......depends how fast the battery went dead as to whether it is good or bad.......should be able to start car for at least 4 weeks based on my experience
3)I would get it charged up like you are doing and then watch the battery voltage......if you don't have a voltmeter, just use the digital meter in the instrument cluster..(With the engine off mine tested about 12.5 volts.....one day later it was 11.5 volts.....conclusion probably one bad cell)...
4)So either have it load tested or just watch it a little to determine what is going on......
A battery that's only two years old shoud be in decent shape. What brand is it and what is the CCA rating? If it turns out you need a new battery, go with the highest CCA rating you can find in a Group 75 battery. Look for a minimum of 700CCA.
As mentioned, have a battery load test done. This should be done on a fully charged battery so have a shop fully charge the battery with a big charger. Check out the charging system too.
There is a possibility that there is a current draw of some sort caused the batery to die. The underhood lights are a possible culprit and they will draw a battery down overnight to the condition you had. Console box light is another one to look at.
Well the battery died, I threw the charger on, car was fine. 3 days later, dead again, threw it on the charger, car was fine. A week later dead again almost, it barely started, but it did start. Took it for a spin and I get the SYS coming on. Just like last time when the battery that came with the car died.
SO now I buy a Battery Tender and the description says OK to use with all Lead acid and gel batteries. Well I have a gel battery. When I opened it up and read the instructions, it says lead acid only.
So I go back to the site and read the description again and the online instructions and it says OK for gel batteries, so I write a letter to Deltran, they tell me I need to get the Battery Tender Plus for use with gel batteries.
I responded with a link to their own site showing where it says OK with gel battery. I have written twice with no response.
So I talked with a few buddies who say that my alternator doesn't care what battery I have it still keeps a charge on it. So I'm wondering why I can't use th etender that says it's OK when the manufacturer says it isn't(but they did say it was OK elsewhere). I think they were just trying to upsell me.
Anyway back to teh dead battery. I had a Diehard Gold in one of my older cars and it was dead the day I brought it home. I brought it back to Sears about 600 times, each time they refused to exchange it, so I lived with it. I had to jump start the car every day to go to work and to get home. When I got gas, I had to leave it running for fear of nobody able to give me a jump.
I tested the battery and found 4 dead cells. I made a vow to never buy a Diehard again(of course I did anyway). I needed a new battery fro my truck, so I took the crappy dead Gold and traded it in for a brand new silver and have had no problems since.
I'm running a NAPA Exide battery in my '93 and that is the dead one in question today, it's barely two years old, so I may ask the guy who sold it to me to exchange it since $100 for a battery, it should last longer than 2 years. It's not holding the charge.
I know checkers and believe auto zone will check it for free for you if you bring it in
To be safe I went to Auto Zone and Advance - not one person in the store had heard of a bettery tender.
The battery I have has a 3 year replacement on it so I have some time to make sure it is right.
Curious as to what kind....will it work as "daily" driver.??
So I talked with a few buddies who say that my alternator doesn't care what battery.
I am not sure this is true....I had battery "expert" tell me this was one of the problems with the AGM batteries, like the Z06 had..
I made a vow to never buy a Diehard again(of course I did anyway)..
I made the same vow....about 1969....I have stuck to it!!!
I think there is difference on battery "float" voltage between the Gel and lead acid. I think the float after the 14.5 full charge on gel is 12.5 and lead acid is 13.8. Thus, the two types of chargers. The company should answer this for you.
Gel batteries can be safely charged and maintained with a battery tender, but be certain that the charger doesn't charge at a maximum rate (usually 10 amps) higher than the battery specifications.
In short, car batteries don't like sitting idle for long (4+ wks) periods of time, so charge them periodically!
From posts on this forum, I don't think there is any advantage to the gel-cell batteries.
RACE ON!!!
I think that everyone agrees that one of two things are happening. Either you have excessive current draw while your car is sitting or a bad cell in the battery.
Mojo,
I'll check out the website, I just wanted to share a little info with you. People have different thoughts on how batteries should be maintained.
I had an alternator rebuilt by an old school shop, and he said the most common cause of alt failure was due to the battery (age, number of times completely dead ...) He also recommended a new batt should accompany any/all rebuilt or new alternator. What would constitute a "new" battery? I guess if it were no more than a year old.I can't tell you how many maintenance free batteries I have had a green eye that wouldn't do squat let alone pass a load test.
Is there even a non maintainence free battery anymore? I haven't shopped for a battery in a few years but last time out I recall almost all being maintainence free.
I bought the Gel Cell based on the understanding that it would take a charge better than the old lead acid type.
Form what I've been told the lead acid can only take a drain so many times before it will crap out for good(which was the case for every battery I've had before 1997).
Other than the Diehard Gold I mentioned above, I've always had good luck with batteries, but with racing seson at a pause and me being lazy and not wanting to put street tires back on, I parked it in the garage expecting to drive it a little more than I actually did.
I didn't expect the battery to crap out after 3-4 weeks, but I did expect it to hold a charge.
I bought the Battery Tender because of all the good things I've heard and my current charger is about 35 years old. SO it was time for soething else. I'm still planning on buying a new charger for use in the garage.
I just wish I would get a reply from Deltran explaining why they say two different things.
In my experience, Exide batteries only last about 2 years. So your battery fell right in line with what I would expect. Personally, I stay away from Exide. I don't know many people who have been happy with it. They normally said they lasted a relatively short time and had to be replaced. Spending that much money on a battery ($100), I would think you had to have received a pretty good warranty (2-3 year full replacement or 7-8 year pro-rated). Or at least I hope you did.
