Are the wheel studs dry and free from grease or oil? Is the flange on the wheel smooth and clean and dry? Are the threads in good shape on both the stud and nut? Did you torque the nut to 100 ft-lbs and re-torque after about 30 miles of driving??
It may also be that the threads are simply worn out from years of removal and re-installing. You might want to get a new set of lug nuts.
Are the wheel studs dry and free from grease or oil? Is the flange on the wheel smooth and clean and dry? Are the threads in good shape on both the stud and nut? Did you torque the nuts to 100 ft-lbs using the correct pattern and re-torque after about 30 miles of driving??
Years ago I had a 1969 Chevelle SS 396 that had the factory steel rally wheels. The wheels would loosen like your talking about. Very scary stuff. It turned out that the taper that the lug nut tighteen on was worn out. When you tightened the lug nuts they were actually tightening against the drum or rotor. It's been a while since I've had my vette wheels off so I can't remember if they have taper seat lug nuts or not. Good luck, I hope you figure it out soon.
Mechanic told me to loosen all lugs and jack up car and then tighten
I lost two lug nuts from the same front wheel back in the fall. In fact, one fell off and rolled up against a mechanic's shoe while I was pulling into a dealership parking lot to look at their showroom Ford GT.
Being the nice mechanic that he was, he brought out his floor jack and had me loosen all of the lug nuts. Then he jacked up that portion of my 1990 Corvette and I re-tightened them. He said something about equalizing the pressure on all of the lug nuts. I had to buy a new lug nut to replace the other one for my Dayton wire wheels. But they've stayed tight ever since.
Zip Corvette, which I visit frequently, told me that aftermarket wheels have to be watched a little more than factory wheels. -- Eric
One good thing about the forum is people do different things that work for them! I tighten the lug nuts on aluminum wheels to about 35 pounds, then 70 and finally to 100. All five nuts are tightened to the same torque, but I skip a nut while doing the tightening process. I know this is controversal, but I always use anti sieze on the studs as this has never caused me a problem (unless I use to much of the compound and it makes a mess!).
SAM
