HELP!! need torque specs
Old Feb 8, 2005 | 10:25 PM
JA94vette's Avatar
JA94vette
Default HELP!! need torque specs
Hey guys I’m running into kind of a jam with time. What are the torque specs on the diff carrier to diff bolts?? (The cover to diff). Also, the tie rod to carrier bolts, the wheel bearing to spindle bolts? I couldn't find the specs in Chilton's. Are the diff cover bolts supposed to be replaced every time the diff cover is off?
Thanks,
Jeff
Old Feb 13, 2005 | 09:28 PM
pipe's Avatar
pipe
Jeff all the bolts on the diff cover are 19lbs. except for the very bottom 2 and they are 30lbs. Also there is a torque sequence for them
Old Feb 14, 2005 | 06:22 PM
JA94vette's Avatar
JA94vette
Thank you very much...Do you happen to know the torque order? Is it criss-cross? Also isn't the bracket for the spidle camber rod 60ft/lbs? That also blots the cover down. Thanks again.
Old Feb 14, 2005 | 09:03 PM
pipe's Avatar
pipe
Jeff, yep the spindle bracket that bolts to the case is 60ft. lbs. thats what my helms manual says. If you could E Mail me a fax # I could send you the torque sequence cause i'm not smart in knowing how to post it on here. Pipeline 310@aol.com and i'll gladly send it and any other specs ya need BILL
Old Feb 17, 2005 | 11:47 AM
JA94vette's Avatar
JA94vette
I'd really apprecitate that...I don't have a fax up here at school so this weekend when I go home i'll get you to fax it then. Thanks again.
Old Feb 17, 2005 | 02:07 PM
CFI-EFI's Avatar
CFI-EFI
You can IM or e-mail Redbullapril23. He either has or is working on a complete set of torque values and sequences for every bolt in all C4s. He's trying to get it posted as a sticky.
RACE ON!!!
Old Feb 17, 2005 | 02:19 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
RACE ON!!!
To HELP!! need torque specs
