i am going to build a 383- use existing block. what items do yall recommend. if i never plan to spray over 150 shot, is ti worth the money for the forged pistons? please provide links or part numbers of what you recommend.
I run a scat cast crank, stock rods w/arp bolts and hyperutectic (sp) pistons. This is low buck and a little risky. A cast crank with stock rods and a cheaper forged piston would be a bit better. You can also use a forged crank, aftermarket rods, and high quality forged pistons. Expect to pay between $800 and $1,700 for a rotating assembly depending on your choice. Many variables and many opinions on the subject.
From: I have no tolerence for liberals and fools, but sometimes i repeat myself
CI 3-5-7-8-9 Veteran
St. Jude Donor '08
I am running an Eagle Forged Crank, Eagle 3D rods with L7 bolts and Forged pistons with full floating pins. Set me back about 1400 before balancing. Let me know if you noeed anything, an buddy of mine is Wharehouse Distributor for Eagle
The best setup for a 383 is an internally ballanced crankshaft (scat and eagle both make an internal balance 383 cast and forged crank for one and two piece rear main seals). This way, you can use the 350 balancer and flexplate/flywheel. Plus, internally balancing is just alot better, IMHO, it's all balanced right, not balanced by weights on the balancer, etc.
Also, if you have the $$$, spring for the eagle H-Beam rods, with some arp wave-locs. My buddy did this setup with a 2 piece 350 block and did not have to do ANY clearancing of the block to fit the rods in (the h-beams have a smaller diameter around the journal than other rods).
If your reusing the Lt1 heads, here's a tip: Port the crap out of the exhaust side, and maybe some bowl work on the intake side. Run a set of Manley Race flo 2.02 1.60 valves, and hold on! These heads were the model for the Vortec heads which came out later. They have alot of power potential.
I'd say use more cam than the popular lt4 hot cam. you have more cubes, better flowing heads than you did before (if you port), and have a higher rpm power potential. Just be sure to upgrade those valve springs! (comp cam conical springs are great)
Hyperutectic pistons are VERY strong. actually harder than forged. The rumors about them being brittle like glass are false. The problems people have with them is when they don't gap the rings to the piston manufacturer specification. If the ring gap is too tight, the ring ends can tighten up and butt against one another, severing the top of the piston.... that's kinda unhealthy for a motor B-).
I'd say the hypers would be fine, IF you gap them right, and IF you are careful about detonation when the nitrous is on. otherwise, go forged.
keep us posted! i'd love to hear how it turns out! I bet you could squeeze 500+ hp BEFORE the spray!
If you're selecting a cast crank, that is a good decision. 383's are torque monsters...not revvers and don't really require a steel crank. Cast crank and mild rods are fine. I went with forged pistons simply for peace of mind.....but I do know a few 383's that used hyper pistons with no problems.
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Originally Posted by 4bblC4
Another thing -
That's the whole deal. Go strictly with the piston maker's recommendations if you're using hypers. Mine required a .026" top ring gap and .018" on the second. Had to hand fit them of course.
I would never consider spraying a hyper piston. In fact i would never consider a hyper piston for a perf rebuild .. period! For whatever reason, i've just seen too many hypers break...even NA. If you plan correctly you can use off the shelf forged pistons for almost the same $ as hypers, so why risk it?
