I am currently deciding wich engine setup to go with and I have learned alot through this process. I wanted to pass this on to you and see what you think. here goes.
ZZ4 short block
LPE 219 cam
L98 heads 113's new not ported or TFS new 23degree heads
Superram setup not ported
TPIS long tubes
let me know what you think of this setup. I am on a budget and wish I could do the AFS heads but they are just to much. With the money I have I can get away with this set up.How many horses do you think I can get out of this.
I'd go with the TFS heads over the 113. The 113 is a good head, but could use porting for a cam and intake upgrade. TFS is probably a better head stock.
You will need some springs setup for the new cam. Might go with some lightweight retainers as well.
