Optispark bolt size
Feb 11, 2005 | 01:39 PM
Optispark bolt size
What size are the screws to take the cap off of the optispark? Torx??
Feb 11, 2005 | 03:07 PM
Quote:
from what I understand, it is just an INVERTED torx.
Here is an older thread covering this topic:
http://forums.corvetteforum.com/show...=inverted+torx
Feb 11, 2005 | 07:18 PM
St. Jude Donor '05-'06
Size E-5 inverted torx I have read.
Feb 12, 2005 | 12:05 AM
Some folks take a torx screw and weld it to a nut and use a regular socket to use the screw head for removal...
Hope that my help...
Mo
Feb 14, 2005 | 01:44 PM
Distributor rotor torx size
does anyone know the torx size to take out the rotor?
Feb 14, 2005 | 02:37 PM
Don't know for sure, but this guy says the rotor Torx size is "really small" !
I would just buy a cheap set of Torx "screwdriver type" wrenches. I do know that the Opti torx screws do not require He-amn type torque, as so much of the unit is made of high impact plastic.....
If you haven't seen this web page, it shows the dis-assmebly procedure for the Optispark unit:
http://www.charm.net/~mchaney/optisprk/optisprk.htm
Good luck, I am about 2 weeks away from replacing my Opti and WP. Are you planning on pulling your Timing Chain cover, and replacing the O-ring seals??
just curious.....
Feb 15, 2005 | 09:04 AM
Torx size optispark rotor
Just some follow up info - the Optispark rotor is removed with a
T8 - got it from Sears $1.99
JIM
Feb 15, 2005 | 12:20 PM
JIM
heh heh, you finally found out!! I am curious, are you doing a cap/rotor replace? If so, where did you buy your cap/rotor? i'm just curious......
Feb 15, 2005 | 01:01 PM
I took the hex screws out of the throttle body and used a pair of vise grips to take my opti apart. Total cost zero dollars.
Yup, I got it from the link above....very informative.
94 ,
95 ,
bolt ,
bolts ,
cap ,
coervette ,
distributor ,
lost ,
lt1 ,
optisark ,
optispark ,
rotor ,
screw ,
screwdriver ,
size
