'95 LT1 loading up heavy, no codes being shown
Old Feb 11, 2005 | 08:31 PM
Dado's Avatar
Dado
Navigator
Default '95 LT1 loading up heavy, no codes being shown
I have a 95 LT1 100,000 miles, fuel is loading up and car is missing bad. Had done this once before a couple weeks ago ( about 6 miles) but cleared up. This time it kept missing, seems like it dropped 3 cylinders. I took it to a local garage looking for some sort of code. None available, they also tested the fuel pressure and said it was good. Spark Plugs,wires and temp sending unit to the computer have been changed with no improvement. MAF cleaned with contact cleaner also no change. Here's the kicker, in traffic yesterday ( at red light) when the cooling fans cut on, the miss seemed to stop but the engine light came on. Four min. later the fans cut off and the light went out and the miss started again. Anyone have any idea?
Old Feb 11, 2005 | 08:42 PM
MikeC4's Avatar
MikeC4
I am not sure what you mean by "fuel loading up", but if your SES light went on, then an error code for this problem should get stored. The code will remain in memory even though the SES light went off. You can save yourself the hassle, and easily pull the codes yourself.
Old Feb 11, 2005 | 08:58 PM
Dado's Avatar
Dado
Navigator
Loading up as if the injectors were stuck open and dumping gas. The smell of raw gas coming out the exhaust with the smoke to go with it. Seems like you could get into it hard going down the road and blow it out but it doesn't work. I read some of advise you gave to another reader (rwsduc 92 automatic) and tried to get the code. Even went to www.obd1.com for answers. Mine has a 16 pin and I don't know which ones to jump for the SES code.
Old Feb 11, 2005 | 09:01 PM
bogus's Avatar
bogus
you need more then a code check for this problem... you need a scan tool, so you can monitor when things blow.
Old Feb 11, 2005 | 09:04 PM
MikeC4's Avatar
MikeC4
you will want to jump pin 4 and 12
http://img169.exs.cx/img169/6905/obd2pinout6ao.gif
Old Feb 11, 2005 | 09:13 PM
Dado's Avatar
Dado
Navigator
Pin 4 and 12 still no code. SES doesn't even flash>>>
Old Feb 11, 2005 | 09:27 PM
Dado's Avatar
Dado
Navigator
Still not sure about fuel pressure regulator. Since it works on vaccum, if I unplug it, cap vaccum line. And drive it down the road it should starve for gas and possibly shut off if you get on it, right?
Old Feb 11, 2005 | 09:32 PM
vetster86's Avatar
vetster86
In my 94 LT1 Camaro I was getting more of a thumping sound in the exhaust (not a miss) and a rich condition (no codes). I narrowed it down between injectors or the ecm. I had heard that the LT1 injectors are known for leaking not when the engine is off but when the engine is running. I also got a gas smell after I shut the car off. I changed out the injectors and no more thumping no more gas small and runs better than ever. Also try unplugging your air flow sensor and see if conditions change.
Old Feb 11, 2005 | 09:37 PM
8388's Avatar
8388
St. Jude Donor '14
As mentioned already, a scanner will go a long way.
Those symptoms are usually associated with a bad MAF. Have you checked the MAF relay ?
Old Feb 11, 2005 | 09:48 PM
Dado's Avatar
Dado
Navigator
Have not checked the MAF relay, don't have any idea where it's located. But I will going after a scanner tomorrow. Thanks for everyone help. I'll let you what happens.
Old Feb 11, 2005 | 10:38 PM
Lone Ranger's Avatar
Lone Ranger
The opposite actually. The vacuum is strongest at idle and low rpm so the vacuum at those speeds causes the FPR to regulate the pressure and prevent it from being too high when there is no demand for that much fuel. As rpm increases vacuum drops so the FPR recieves less vacuum which causes it to "open up" and allow more fuel pressure to the injectors. This way, at full throttle the FPR is "wide open" so to speak and not regulating the pressure so that the injectors get full pressure when they need it for full throttle.
Old Feb 11, 2005 | 10:43 PM
Lone Ranger
What injectors did you end up going with as replacements? My '95 almost has the same muffled "wump" in the exhaust note, but only at idle and fades away when going off idle. I've always felt my car has ran slightly rich, even changed the oxygen sensors this fall with only 40,000 miles on the car to see if it would help lean it up some.
Old Feb 11, 2005 | 11:14 PM
Dado's Avatar
Dado
Navigator
Orginal injectors and this is not a little miss, it will actually jerk as you drive it down the road.
Just removed the plugs again. L/H side clean as new, R/H side fouled. This wasn't the case the first time. But does this sound like the Opti spark?
Old Feb 12, 2005 | 12:37 AM
MikeC4's Avatar
MikeC4
Your codes will be displayed where the LCD fuel gauge is, not flashing SES light which is for older C4's.
Anyway, your problem appears to be more serious than a faulty O2 sensor or TPS switch. But go ahead and see what codes you get. Is your Optispark original? If you have 100K miles on your Opti, then this could be your problem. Check to make sure your water pump is not leaking through the weep hole onto the Opti, weep hole is at the bottom of water pump. Has the engine been exposed to alot of water recently. Anyway, I've read where Opti's should be replaced every 60K miles as routine maintanance....
Old Feb 12, 2005 | 05:52 PM
vetster86's Avatar
vetster86
I ended up going with the LS1 injectors and they work very well, You just have to do a little mod to them so your fuel rail clips will fit. I did a thread awhile back called ( anyone running LS1 injectors in a LT1 if so..........) I think its back around the 5th or 6th page.
Old Feb 12, 2005 | 06:38 PM
Lone Ranger
LS1 squirters are Multec II, right?
Old Feb 12, 2005 | 06:49 PM
vetster86's Avatar
vetster86
Don't know, but they work
To '95 LT1 loading up heavy, no codes being shown
Old Feb 13, 2005 | 12:58 AM
Dado's Avatar
Dado
Navigator
Update: Finally got the codes pulled, thanks MikeC4. 63,64 both reflect O2 sensor R/H side. Went ahead and replaced sensor and plugs again tonight. Have not tried to drive it yet. Idles fine, no smoke yet. Got my fingers crossed.
Old Feb 13, 2005 | 01:25 AM
Lone Ranger
An O2 sensor has to be really fouled hard to throw a code. My guess is your problem is now fixed after the sensor change.
Let us know!
Old Feb 18, 2005 | 12:57 PM
Dado's Avatar
Dado
Navigator
Replaced O2 sensor, cleared up 50%, unplugged MAF,and check engine light came on but runs great. Looking for a new sensor, is this it?
