422ci LT1?
Old Feb 17, 2005 | 03:20 PM
cprgmr's Avatar
cprgmr
Default 422ci LT1?
I've been doing some research into building a stroker (leaning towards a supercharged application).
I know SonnyinVA has a 409 (4" crank, 5.850" rods with a 4.030" bore), and based on this article - TPiS 409 TPiS did a 4.100" bore on a LT1 for a 409 (3.875" stroke, 5.85" rods). I always thought the maximum bore you could safely go before hitting water was about .060"?
What about combining the two for a 4.100" bore, a 4" stroke, and 5.85" ProMod rods? Based on the displacement formula, this should yield a 422 correct?
Thoughts?
Old Feb 17, 2005 | 03:23 PM
Nathan Plemons's Avatar
Nathan Plemons
Rod length has nothing to do with it. It's a consideration but ultimately it only affects your piston choice, not displacement.
That being said you can use this spreadsheet and play with bore and stroke all you want.
http://www.wku.edu/~nathan.plemons/calc.xls
Old Feb 17, 2005 | 04:21 PM
Timmy!'s Avatar
Timmy!
Judging by how thin my cylinder walls were when the rod went through the side of it with only a .030 bore, I don't think I would bore it more than .040 on an LT1 block.
That's quite the spreadsheet Nathan - thanks for posting that.
Old Feb 17, 2005 | 07:11 PM
BAM92's Avatar
BAM92
There was a guy down here who had a shop called CXI who had a 421 LT1. He used to run alot of nitrous through it(400hp supposedly) He had a valve train failure that ended up destoying motor. He is in jail now for ripping people off.
Old Feb 18, 2005 | 01:20 AM
korvetkeith's Avatar
korvetkeith
Old Feb 18, 2005 | 08:54 AM
cprgmr's Avatar
cprgmr
Agreed, however I find it's always helpful to provide this info as it has an impact on what kind of clearance work has to be done to the block (as well as maintaining a desirable rod ratio).
Old Feb 18, 2005 | 08:55 AM
cprgmr's Avatar
cprgmr
Interesting - I wonder how some get away with going .060" much less .1? Do you have any pics of the cylinder walls you'd be willing to share?
Old Feb 18, 2005 | 09:01 AM
ASRoff's Avatar
ASRoff
The only way to be safe is to sonic test a block before you have it bored. you could possibly have the block sleved to accomidate a uniform cylinder. Try Darton Sleves to see if they make anything like this. By the way sleving a block is not cheap.
Old Feb 18, 2005 | 10:40 AM
rocco16's Avatar
rocco16
From: SCMR Rat Pack'r Charter Member..Great Bend KS
Individual blocks will have different minimum cylinder wall thicknesses, depending on core shifts during the casting process.
Larry
code5coupe
Old Feb 18, 2005 | 10:58 AM
tjwong's Avatar
tjwong
Darton doesn't make a integrated deck type sleeve like they do for the LS1 series engines for the LT1 engines. You can use a conventional type sleeve, but its not going to be cheap. Anything is do able if there is enough cash.
Old Feb 18, 2005 | 11:04 AM
tjwong's Avatar
tjwong
Old Feb 18, 2005 | 11:36 AM
Timmy!'s Avatar
Timmy!
Here's one:
Old Feb 18, 2005 | 12:53 PM
Mo_Bandy's Avatar
Mo_Bandy
That's gotta hurt
Mo
Old Feb 18, 2005 | 01:07 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
I've seen people pour epoxy into the coolant passages so they could notch for a bigger stroke. But by the time you get through I think your better off getting a turbo or a blower
My 2c
Old Feb 18, 2005 | 01:10 PM
Timmy!'s Avatar
Timmy!
Do those cylinder walls look thin to anyone else or am I just not used to seeing what a cylinder wall looks like with a hole punched through it?
To 422ci LT1?
