windshield wipers hitting
Old Feb 12, 2005 | 12:37 AM
LT1CORVETTE's Avatar
LT1CORVETTE
Default windshield wipers hitting
I am having a problem with my windshield wipers on my 96 coupe. On their way back down before they are in their semi cocked "on" resting position they clip one another. Not a drastic hit, bit they definetly make conatct every time they come back down. Is there a way to adjust them so they don't do this?
Old Feb 12, 2005 | 01:02 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
This is a common problem on earlier C4s but is usually cured by using 95-96 style arms. They could be installed wrong or the linkage could be worn. Some have solved the problem by using premium blades too.
Old Feb 12, 2005 | 06:03 AM
CF6873's Avatar
CF6873
Do you have Rain-X on your windshield? When I had it on my 94 the wipers would collide. Without it they are fine.
Old Feb 12, 2005 | 06:55 AM
Richard G's Avatar
Richard G
I tried the adjustment and finally solved my blades fighting each other by going to a smaller blade on the drivers side. I believe I went with 16 inch blade. Now both blades like each other.
Old Feb 12, 2005 | 08:50 AM
REW89's Avatar
REW89
Visit here.........
https://www.corvetteforum.com/techti...D=42&TopicID=2
Bob
Old Feb 12, 2005 | 10:43 AM
Midnight 85's Avatar
Midnight 85
Finalist 2020 C4 of the Year - Modified
If you will send me your email address I will send you Gordon Killebrew's step by step method of correcting wiper crash. While the newer arms are definitely a good idea you might want to try this before spending money.
Old Feb 12, 2005 | 11:07 AM
95polo's Avatar
95polo
I had the same problem with my '95 which has the late c4 style arms. I guess over the years the driverside arm had flattened out and the arm was almost touching the windsheild. When driving with the wipers on sometimes they would collide. I don't remember anything hitting the arm to cause it to bend. I also think that in '95 GM increased the wiper arm spring rate to cause a firmer contact with the blade to the windsheild. I fixed my problem with a new wiper arm.
Old Feb 12, 2005 | 12:51 PM
TheCar's Avatar
TheCar
I was able to bend my arms by removing them and putting the smaller flat portion in a vise to get them to clear each other and the A pillar. didn't know about the new arms.
Now they park where I want them to, and don't hit anything. I figured if I wrecked them I could always get new ones later. All it takes is the guts to try. and it was free too.
Old Feb 12, 2005 | 11:07 PM
flylowguy's Avatar
flylowguy
Default you can probably adjust the crash out of them
pry up the plastic screen access cover on the driver's side below the windshield. Use an extension and a 10mm socket to loosen the four nuts on the two push-pull extensions. Don't drop the socket, it's a bummer if you do. I don't want to talk about it.
When they are loose you can move the driver's side wiper arm down (I moved mine a lot, about 2 1/2" below the stops, measured at the inboard tip), and move the passenger side wiper arm a little down so it will tuck away behind the hood edge. Don't forget to put the driver wiper arm back up into it's proper resting position in the stops. Snug the nuts and try it. Don't leave the extension and socket on when you try it. I don't want to talk about that either.
Ok, after a few tries, you should be able to find a happy compromise of positions so they don't crash, and they tuck away like they should.
Old Feb 13, 2005 | 11:59 AM
TheCar's Avatar
TheCar
MAN! I wish I knew that before I started bending things. oh well thanks for the info at least now I will be able to help others do it the RIGHT way. Guess I'm just a hack.
Old Feb 13, 2005 | 09:03 PM
SilverBeast's Avatar
SilverBeast
St. Jude Donor '05
I had that problem. Somewhere is a thread with my final fix. Basically it was using Soft-Scrub to completely clean the windshield, then removing the transmissions (left and right) and lubricating them (they were both dry). I initially did only the driver side, but went back later and did the passenger side as well. It may be a simple adjustment, and if so, congratulations. I tried everything before dismantling mine and lubricating. DO be careful with the sockets - when they go, they go a long way.
Old Feb 14, 2005 | 08:33 AM
runner140*'s Avatar
runner140*
Default Eighteen months ago....
When I purchased my C-4, I was driving home on the turnpike when it started to rain. I had wiper crash. When I got home, changed the arms and the wipers and never had the problem again.
Old Feb 14, 2005 | 12:55 PM
90Indy's Avatar
90Indy
Not a problem. I don't drive mine in the rain.
90Indy
Old Feb 14, 2005 | 05:14 PM
Daffy's Avatar
Daffy
Florida turtle advocate
St. Jude Donor '05-'06
I install teflon blades on my cars....Fixes the problem
To windshield wipers hitting
