Does anybody know?
Old Feb 12, 2005 | 03:54 PM
CF6873's Avatar
CF6873
Default Does anybody know?
I just replaced the OPTI, water pump, intake gaskets, plugs, wires, and coil on my 94 and I have a bolt left over. It is a 1/4-20 X 1 1/4" long with a 3/8' head. I can't find a hole for it. Does anyone know where it belongs? Thanks
Old Feb 12, 2005 | 04:22 PM
bogus's Avatar
bogus
gee... too long to be an opti bolt; those are rather short, really.
Not a balancer bolt, not stout enough.
I wonder if it's for the fuel injector rail, maybe... I would check intake manifold... it's not long enough for the throttle body, tho...
Old Feb 12, 2005 | 04:49 PM
FostersPerformance's Avatar
FostersPerformance
Old Feb 13, 2005 | 10:33 AM
CF6873's Avatar
CF6873
Yes, this is quite puzzling. I got a mirror and checked the opti bolts(all there). I have looked all over with a mirror and a flashlight and I just can't find a place for this. Of course it doesn't help that all this work was done over the period of a month. My memory isn't what it used to be. I was in no hurry with snow on the ground. However the car runs good and there is nothing rattling or leaking so how important can it be?
Old Feb 13, 2005 | 11:23 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Theory has it that if you'll just remove the oil cap and drop it in, eventually it'll get back to the right place...... I'll scratch my head a little and look around on my car and see if it jogs my memory. I've had all of that stuff off and on three times.
Old Feb 13, 2005 | 12:06 PM
clearwater_shark's Avatar
clearwater_shark
That goes in the nut and bolt bin top left on your work bench
Old Feb 13, 2005 | 12:25 PM
Corvette Kid
I'm assuming that since you were so precise in your dimensions that it is definitely not a 6mm bolt w/ a 10mm head then, right? Otherwise, my best guess at this point is possibly a timing cover bolt? The power steering pump to bracket bolts are metric and I just didn't see much else with similar specs.
Old Feb 13, 2005 | 01:17 PM
CF6873's Avatar
CF6873
I don't recall removing any timing cover bolts and don't know why I would have, but it does seem about the right size. I will take a closer look. Thanks
Old Feb 13, 2005 | 02:25 PM
snoopdan's Avatar
snoopdan
Well, you havent properly repaired something unless you have parts left over. Looks like a power steering mount bolt to me. But ive only done it once.
Old Feb 13, 2005 | 02:38 PM
Chris_G's Avatar
Chris_G
St. Jude Donor '05-'06-'07
I think your buddy threw it in there as a cruel joke
Old Feb 13, 2005 | 02:42 PM
MikeC4's Avatar
MikeC4
I can only generalize on this one. Since the bolt has oil deposits, I would venture to say that it came off the front of the engine, and probably not from the Intake area....
Old Feb 13, 2005 | 02:45 PM
Corvette Kid
That's right, you wouldn't have, would you. Except for the three opti bolts which double as cover bolts too. But they're longer than that, looking at my spare set of cover bolts. The P/S pump to bracket bolts on mine have a 10mm head so that would seem to rule them out, if you even had those out. I'll continue to ponder as I install CV boots on the good looking (and single) neighbor lady's Honda....
Old Feb 13, 2005 | 03:56 PM
SanJacRT's Avatar
SanJacRT
Could it be the short lower water pump bolt that sits just slightly above and behind the idler pully on the driver's side? Its kinda hidden from view when the pump is installed, and may have fallen out unnoticed while you were torquing the other three.
Jeff
Old Feb 15, 2005 | 07:31 PM
SanJacRT's Avatar
SanJacRT
Jeff
Oops, I meant to say the belt tensioner rather than the idler pulley.
Jeff
Old Feb 15, 2005 | 08:24 PM
NeedSpeed's Avatar
NeedSpeed
Yeah, it looks like a water pump bolt.
Old Feb 15, 2005 | 09:11 PM
CF6873's Avatar
CF6873
The water pump bolts are 3/8" with a 9/16"head. This bolt is only a 1/4" with a 3/8" head. I'll keep looking. Thanks
To Does anybody know?
