HOW DO YOU GET TO REAR SPOILER NUTS THAT MOUNT THE SPOILER?
I HAVE TRIED FROM UNDERNEATH, TOP SIDE BY REMOVING GAS DOOR, EVEN REMOVED TIRE AND FENDERWELL, ALL TO NO AVAIL.
I believe the same way you change the brake lights when they go - through the license plate. Remove it, and stretch your arm through the hole like Stretch Armstrong (for those of you old enough to remember him).
o yea tried that to ,was able to get to one of them but tail light is in the way.Where can i find that armstrong guy? Surely i dont have to take bumper cover off? Any other suggestions anyone?
If you reach thru the license plate hole, you can take out the nearest taillight, go thru that hole to take off the outer taillight. There are 2 10MM bolts holding each tailllight on.
That might give you room enough.
If that doesn't work, I guess the bumper has to come off.
There was one of these ugly things on my C4 when I bought it. I thought it made it look like a rice burner. THere were 3 mounting points, each with 2 bolts. The center ones were accessed through the license plate hole, the outer two were done from below with an 18" extension. If you don't want to save the spoiler, a sawzall works well.
